HELP!!!! plug wires
Old Sep 25, 2003 | 07:25 PM
88 L98's Avatar
88 L98
Default HELP!!!! plug wires
I just got some new Accel's for my car. does anybody have a easy way of removing the old wires? this looks like it's gonna be a PITA. it's really cramped and I have fat hands.
Old Sep 25, 2003 | 07:29 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: HELP!!!! plug wires (88 L98)
Get some spark plug wire pliers at the local parts shop. They'll save you from having to jam your hands down there. For the plugs, remove the front wheels and fenders, and go in from the side with extensions.
Old Sep 25, 2003 | 07:33 PM
88 L98's Avatar
88 L98
Default Re: HELP!!!! plug wires (JCAIRE2)
will that help me remove the wires if I remove the wheels and fenders? the part I can't get to is under the cap and all. where they run down towards the ground and then pop back out and head to the engine.
[Modified by 88 L98, 6:34 PM 9/25/2003]
Old Sep 25, 2003 | 07:46 PM
dbwade36's Avatar
dbwade36
You don't need to remove tires to replace the plugs. They will come off, sometimes easier w/pliers. Do them one at a time, so as not to make it confussing.
Old Sep 25, 2003 | 07:50 PM
vader86's Avatar
vader86
Default Re: HELP!!!! plug wires (dbwade36)
Just do it one at a time.
Old Sep 25, 2003 | 08:40 PM
88 L98's Avatar
88 L98
Default Re: HELP!!!! plug wires (vader86)
I'm not sure if you guys know what I'm talking bout. pluge have been CHANGED ALREADY. I am replacing my WIRES now. there being a PITA. I only have 2 done so far. is there anything that can help me do this? This as in changing the wires
Old Sep 25, 2003 | 08:48 PM
dbwade36's Avatar
dbwade36
I did notice the response about plugs, but mine was about wires. Wires aren't all that tough, if you keep them in order. You can # them & do them one at a time, pull out one old wire & replace w/one new wire. Do this eight times, job done!
Steel Blue 91's Avatar
Steel Blue 91
Just do them one at a time and have patience. No need to be too gentle with the old ones if you plan to trash them.
[Modified by Steel Blue 91, 8:49 PM 9/25/2003]
Old Sep 25, 2003 | 09:10 PM
vader86's Avatar
vader86
YES, DO ONE AT A TIME.
If you cant get your fingers in there, get someone else to do it.
My hands are 9 inches long from wrist to middle finger, and i dont need any damn tools, just DO IT.
Old Sep 25, 2003 | 09:38 PM
Red90Coupe's Avatar
Red90Coupe
9 inches!!!!! Good Gawd.... How tall ARE you Vader? :D
Old Sep 25, 2003 | 09:57 PM
dbwade36's Avatar
dbwade36
Default Re: HELP!!!! plug wires (Red90Coupe)
Damn, that IS long Vadar! Mine are only 7 1/2 inchs from wrist to middle finger & I am 5' 10". BTW- No comments about hand size = hmm, other body part size, because I am about the same as mentioned above, down below. :) Want to be a **** star when I retire from the Air Force. hehe
Old Sep 25, 2003 | 10:03 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
My hands are huge also i feel your pain .This is what i did you have to get a pair of mechanics gloves save skin & less blood loss.First remove wires from looms if not they brake start with driver side save the hardest one for last.The NUmber 2 under the a/c is the hardest.Good Luck
Old Sep 25, 2003 | 10:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The easiest way is to remove the dist cap first. Put a little liquid wrench on the hold-down screws as they can become corroded.
The pull the existing wires one at a time and replace with the new ones. Label the top ends so you know where they go.
Old Sep 25, 2003 | 10:10 PM
Southern Comfort's Avatar
Southern Comfort
:iagree: take them all off....get a phone call.....and bam! have to figure it all over again.
One at a time nice and easy. Since you are only 15 I will only tell you to get a lemonade and kick back. :cheers: (those are not suds...they are lemons)
Old Sep 26, 2003 | 04:34 AM
88 L98's Avatar
88 L98
Default Re: HELP!!!! plug wires (Southern Comfort)
lol. I hate lemonade, gimme a coke. I got them done a hour or two after I posted that and it runs fine now. nothing wrong. then i moved on to the starter. I have it removed and am waiting till morning to install the new one. this should be fun :yawn: hopefully it wont be too hard. and then my car will fin ally be running in tip top shape! ( I hope ) my next step is to get the lights fixed then finally move on to interior :D
To HELP!!!! plug wires
