LS1 Injectors
Old Sep 27, 2003 | 11:45 AM
voodooracer's Avatar
voodooracer
Cruising
Default LS1 Injectors
Will LS1 injectors fit the LT1? If they do it will surely help the pocketbook. :reddevil
Old Sep 27, 2003 | 12:07 PM
bogus's Avatar
bogus
Default Re: LS1 Injectors (voodooracer)
for some reason, I don't think so...
a good option are the Ford Motorsport injectors... about 200.00 a set from Summit Racing.
Old Sep 27, 2003 | 01:59 PM
Zix's Avatar
Zix
Yes they will fit, I believe they are 28.8 lbs, but you will need to buy an adjustable fuel pressure regulator because to get that 28.8 rating the LS engines use mid 50+ fuel pressure.
To LS1 Injectors
