Do you have a fan in front of your radiator? This is the one that is controlled by the switch. The rear fan is totally controlled by the PROM. A quick reprogram will fix that for you. The switch goes into the side of the head, between a couple of the header tubes. It is a single (green wire) connection.
That temp switch is for aux fan, which you said you don't have. But you can still wire into main fan relay with a single wire.
The switch goes into drivers side of block between 1 and 3 cyl.
That temp switch is for aux fan, which you said you don't have. But you can still wire into main fan relay with a single wire. The switch goes into drivers side of block between 1 and 3 cyl.
:iagree: And yes, since you don't have dual fans you don't need the harness.
You realy don't need a wiring harness to wire an aux fan switch to control the main fan.
You can buy the connector for the new switch (if one doesn't come with the switch), get a length of grn wire and route the wire over the the large harness running along the left inner fender well. Then bring that new grn wire out near the main fan relay (on the rear of the left inner fender well) and splice it into the grn/wht wire going to that relay. You can bet splincing connectors at Radio Shack to do this job.
