LT1 to LT4 conversion Kit ???
Old Sep 30, 2003 | 11:20 PM
blkc6z51's Avatar
blkc6z51
Default LT1 to LT4 conversion Kit ???
In the Summit racing catalog, they have a LT1 to LT4 conversion kit.
Is it worth $2300. They say it will make a proven 425+ HP will it or
is it bull. Also need to make mods to computer what mods would have to be made. One more thing if this kit makes 425+ HP for my LT! why dose the
LT4 only make 330HP.
:confused:
Old Oct 1, 2003 | 12:07 AM
tjwong's Avatar
tjwong
Default Re: LT1 to LT4 conversion Kit ??? (94TR)
It was documented in CHP magazine a couple years ago when the LT4 first came out. GM then introduced the LT4 hotcam and that was what made the difference for the LT4 making the reported 425 Hp or there abouts. But if I remember right that reported number was on a LT4 engine that had a carburetor on it, but I can't say for sure.
The LT4 was never delivered with a HOT cam installed its strictly an aftermarket cam that came out after the LT4 was introduced and it is not CARB approved, but with tuning it can be made to pass emissions easily.
Old Oct 1, 2003 | 01:07 AM
vader86's Avatar
vader86
I would just do the LT4 hotcam, 1.6rr, and have the stock heads ported.
You should come out cheaper, and be faster. (with exhaust)
Old Oct 1, 2003 | 11:22 AM
1996man's Avatar
1996man
94TR: what all is included in that kit? i would think maybe about 390 fly wheel hp but not 425 you got me curious now what is different in that kit except the cam from my factory LT4!
Old Oct 1, 2003 | 11:32 AM
QuikZilver's Avatar
QuikZilver
Default Re: LT1 to LT4 conversion Kit ??? (1996man)
I was dreaming of this kit too. This is what the kit includes:
LT4 cylinder heads with valves and springs
LT4 intake manifold (red powdercoated)
LT4 Hot Cam
1.6:1 Bow Tie roller rockers
All necessary gaskets.
Quote in catalog: "The kit will give you a proven 425+ HP." On the other page in the catalog, they have the LT4 intake manifold and state "This intake manifold not only supports 425+ HP, its..."
Note: Modifications to your vehicles's computer engine management system are required. 1992-93 applications require a 1994-95 fuel rail.
Part #'s:
NAL-GMP3287-1 1992-95 $2,289.95
NAL-GMP3287-2 1996-97 $2,329.95
I guess the 1997 reference is for the Camaro.
It is a really nice upper end kit. I would also get new pushrods with it. Doesn't seem to include those.
Old Oct 1, 2003 | 12:28 PM
Goody's Avatar
Goody
why dose the LT4 only make 330HP. :confused:
It doesn't, it makes closer to 350HP. The factory down rated it because of the 345HP over rating on the LS1 for the new C5.
Old Oct 1, 2003 | 03:24 PM
1996man's Avatar
1996man
Default Re: LT1 to LT4 conversion Kit ??? (Whitvette)
i guess im still not sure how it makes 425 hp the only thing different from my motor i see is the cam and that only adds 30rwhp tops from what i have seen. Am i missing something?
Also do you have to pull the engine to do the cam swap or can you just take the radiator out and have enough room?
Old Oct 1, 2003 | 03:36 PM
Goody's Avatar
Goody
The 425 was flywheel HP not at the wheels. Depends on dyno, depends on temps, gas quality, timing, etc....it could happen.....gotta have a chip programmed to get the full benefits of a cam swap now.
Engine needs to be lifted about 1" to clear the front crossmember. Use a floor jack with a block of wood under the oil pan to spread the load.
Old Oct 1, 2003 | 05:30 PM
95Purple's Avatar
95Purple
I just did the LT4 Hot cam on my LT1. I have ported heads and Tpis Long tube headers. Just had it tuned on the dyno at 277 rwhp. :(
Old Oct 1, 2003 | 05:34 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Default Re: LT1 to LT4 conversion Kit ??? (95Purple)
What kind of torque increase did you get? Also, any idea what the HP/Torque rear wheel numbers were before your mods? Thanks!
Old Oct 1, 2003 | 11:18 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Corvette Fever also did a story on this set up. LT1 to LT4. They used More Performance to do the insall and test at the flywheel on a dyno. 429hp and 400lb ft torque. They used LT4 heads and intake, Hotcam kit, GMPP 1.6 full roller rockers, 52mm throttlebody, custom chip, headers with performance cats. The Main difference in the stock LT4 set up would be the HOTCAM, 52mm throttlebody, custom chip and exhaust. I'm guessing that would be enough to get you 100hp over the stock LT4
Old Oct 1, 2003 | 11:24 PM
TOO_HOTTVETTE
Did you have a custom chip installed? Dont forget that the LT4 heads and intake will also flow better than the LT1
Old Oct 1, 2003 | 11:29 PM
shane99's Avatar
shane99
Default Re: LT1 to LT4 conversion Kit ??? (TOO_HOTTVETTE)
Give this a read. Scanned article from Chevy High Performance
http://www.moreperformanceinc.com/lt4artic.htm
[Modified by shane99, 4:31 AM 10/2/2003]
Old Oct 1, 2003 | 11:37 PM
TOO_HOTTVETTE
Default Re: LT1 to LT4 conversion Kit ??? (shane99)
This is basically the same article that appeared in Corvette Fever. It has the same author. I did this install in my '93 Vette
Old Oct 1, 2003 | 11:56 PM
comp94's Avatar
comp94
Default Re: LT1 to LT4 conversion Kit ??? (vader86)
he has a 94 an lt-4 hot cam will not fit
more performance also offers a kit that claims 425 hp it is a little more expensive but it is also more complete heres the link http://www.moreperformanceinc.com/383lt1.htm
[Modified by comp94, 5:04 AM 10/2/2003]
Old Oct 2, 2003 | 01:07 AM
BAM92's Avatar
BAM92
Default Re: LT1 to LT4 conversion Kit ??? (comp94)
:iagree: You either have to change timing cover, opti, timing chain, or alter the pin on end of cam as others have.
Old Oct 2, 2003 | 02:16 AM
Goody's Avatar
Goody
There is something seriously wrong with your setup if all you have is 277. Most stock LT1's make 260RWHP. Was it dyno tuned with a WBO2 installed? Are you using the 1.6 RR's as well? They are required to get the full lift benefits of this cam. The LT4 and LT1 cams are really close to each other in actual measurements, but the RR's make a bit of difference due to rocker geometry changing total lift.
Also, the LT4 uses 28# injectors, whereas the LT1 has only 24#'ers. I'm curious what your injector duty cycle is at. Are your heads really "ported" or just gasket matched?
To LT1 to LT4 conversion Kit ???
Old Oct 2, 2003 | 10:01 AM
1996man's Avatar
1996man
can someone post a link where this is easier to read or something? i dont know if my eyesight is failing or what but that print is awful faint
Old Oct 2, 2003 | 10:48 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: LT1 to LT4 conversion Kit ??? (Goody)
There is a very important question here. What type of dyno did they use. If it was a Mustang dyno it will read very low numbers compared to the much more common dynojet. If it was a Mustang dyno the numbers don't really mean anything unless you had a baseline before your mods.
If it was a dynojet then yes you have something seriously wrong with your setup. If you are using 1.6 rockers, or have the hot cam kit, you should be WELL above that in horsepower. Even on stock heads my Hot Cam with headers made 336 horsepower. With ported cylinder heads I was up to 365.
The 24# injectors will most likely have a less than optimal duty cycle but they will work. If you don't believe me, look at my setup, I'm currently running stock injectors.
BTW, even with 1.5 rockers the hot cam should make well over 300 with headers and heads. Even if the heads are stock it should make 300 with headers.
If it's a Mustang dyno it could be normal but it still seems low. If it's a dynojet you've got issues, possibly the cam is out of time. Any strange driveability issues?
Old Oct 2, 2003 | 12:18 PM
all4c4lt4's Avatar
all4c4lt4
:iagree: and port your intake.
