I was told by a reputable performance mechanic knowledgeable with Corvettes that I would pick up 5-7 additional HP by removing the screen from the MAF.
First of all, how would removing that piece of what looks like mosquito netting gain that much horsepower, and if I WERE to remove it, how is it done as I see no way of dissassembling the unit to get it out without buggering up those little crosshair wires?
Hmm I don't think so. It does however changes the calibration a little so the car may even run richer. I had a LT1 I was tuning the other day and the fuel trims was indicating rich until I was told that there was a descreened MAF installed, I wasn't sure what was causing the trims to show rich. So once a stock MAF was installed the trims fell right back on track. The very same thing happens with changing a stock MAF with a aftermarket unit, you just don't know where the calibration is with them things. Sometimes and it happens more often than not, you may even loose power.
Hmmm, the fellow who ran the dyno said the read-out indicated that it was just a little lean from 2500 to 4000 rpm and then got rich after 5200 rpm. Of course, this maybe due to the 52mm TB I'm using. So maybe I WOULD want to remove the screen to "balance things out" a bit, so where the sensor would read an increase in air and compensate with more fuel.
It's a worthwhile mod for an L98, but not for an LT1/LT4
:withstupid: The screens and the plastic ring they are in are just glued on to the center piece. I just took a pair of pliers and pulled on the plastic ring.
removing the screen and installing a throttle body coolant bypass seemed to help mine out quite a bit. Did both mods at the same time and was pleased with the results.
Tuffshift, don't bother removing the screens on you 96, the computer will eventually compensate for the change and you will have gained nothing. BTW, the screens are not there to "catch" debris. They are there to straighten the flow of air before it reaches the intake. It is a left-over design feature and is not really needed on corvettes, due to the short and straight path of the intake. It is also used by GM on trucks and camaros, which have bends in the intake requiring the screens.
Couple of questions. I am thinking of removing my screens on my 86 Vette. Someone mentioned that it may be beneficial for L98 engines. Why is that? Also, if anyone knows, will this affect emissions testing in California? Is it true that I can just use a pair of plyers to remove the plasit ring around the screens & can I therefore, put them back on if I choose to?
Why not go to your local junk yard and see if you can buy one for about 50 bux or so. Then take your stock unit and gently pack it away and store it. Cut the screens out of the junk one and file down the sensors using a dremel.
If it's not everything you hoped for, just return the stock unit to the engine.
Mid-eighties Camaros and Firebirds used the same Bosch unit.
