Injector cleaning
http://www.witchhunter.com/
Here's some of his services:
Fuel Injector Cleaning and Flow Testing
Visual Inspection
Remove injector screens, o-rings, and pintle caps
External cleaning
Test injectors for resistance, shorts, and current draw
Leak test
Flow test each injector and check spray pattern
Ultrasonic cleaning while injectors are cycled
Repeat leak test, spray pattern, and flow testing
Install new screens, o-rings, and pintle caps
Generate a comprehensive test report
Set of 8 injectors $96.00
Fuel Injector Flow Testing Only
Visual Inspection
External cleaning
Test injectors for resistance, shorts, and current draw.
Leak test
Flow test each injector and check spray pattern.
Generate test report
Set of 8 injectors $40.00
Flow Matching of multiple Injector sets
Flow testing and matching of injectors at up to 10,000 RPM.
Call for pricing
Normal turnaround times are 48 hours. Please contact us with your injector information before shipping your parts for current turnaround times.
Download, and fill out the injector information form include it with your injectors.
I can't say enough good things about the way he runs his business.
[Modified by sraft, 8:48 AM 10/3/2003]
They can (rarely) develop a short in the coil either to the case or to an adjacent winding.
They can leak externally (not so rare)
The spring or pintle can break or get damaged (rare)
Particles in the fuel line can plug injector (not often as this is usually caught in the filter, either in-line or injector inlet filter.
Most of the time, the injector pintle tips get deposits baked on after shutdown. How much depends of the quality of the fuel used and driving habits.
Ultrasonic cleaning will in most cases clean the injector to almost as good as
new and in most all cases stop a leaker if build-up was the cause.
Flow testing will find any weak or broken springs and compare the flow rates between the individual injectors of a set.
Electrical coil tests will look for any shorted windings.
All in all, cleaning and testing used injectors are a sensible alternative to buying a new set. Factory GM Multecs are very expensive and the SVO's will work, but are not identical.
I depends on your budget and future plans for the engine.
GM Multec's are a noisy injector, due to the internal design and the case. Not a real issue.
Gordon
