What the hell is this?
Old Oct 8, 2003 | 09:03 PM
Twanster2000's Avatar
Twanster2000
Default What the hell is this sensor?
I know it has something to do with the EGR system becuase it's on the EGR pipe. The wire broke off of the top of it and now the EGR is stuck open all of the time. I tried soldering it, but it just got to hot for the solder and broke again. It looks like a temperature sensor of some kind but I can't find any descriptions of it in my manual. Any suggestions. 86 stock.
[Modified by Twanster2000, 2:06 AM 10/9/2003]
[Modified by Twanster2000, 2:07 AM 10/9/2003]
Old Oct 8, 2003 | 09:12 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: What the hell is this sensor? (Twanster2000)
It is the egr temp switch. It has no effect on the opening or closing of your egr. It tells the ecm when the egr is opened or closed. You need a replacement.
Old Oct 8, 2003 | 09:37 PM
Twanster2000
Default Re: What the hell is this sensor? (PeteL)
Ok, so if it disconnected for the time being, it has no effect on anything? The egr will open and close normally?
Old Oct 8, 2003 | 09:40 PM
92corvette's Avatar
92corvette
Huh?
Old Oct 8, 2003 | 09:44 PM
PeteL's Avatar
PeteL
It will set off your SES light.
Old Oct 8, 2003 | 09:56 PM
Twanster2000
Right, but other than that? I know it might mask other problems, but I don't seem to have any problems right now.
Old Oct 8, 2003 | 10:03 PM
PeteL's Avatar
PeteL
I will have no other effect, it is only a sensor to tell the ecm of the status of the egr valve. It controls nothing. The egr will act as commanded by the ecm. However, the ecm will think the egr has failed. I do not believe that this will put the ecm into limp home mode.
[Modified by PeteL, 10:04 PM 10/8/2003]
Old Oct 8, 2003 | 10:18 PM
Twanster2000
Cool, thanks. I'll get it ordered soon.
To What the hell is this?
