Problems with hood support??????????????
Old Oct 11, 2003 | 06:21 PM
EDMGUY's Avatar
EDMGUY
Default Problems with hood support??????????????
Ok I bought everthing I needed to upgrade my 84 to a 96 body style bumpers, inner wheel wells, lights the works. :D. I started on changen the right side inner wheel wells.Have them all change looking good :thumbs: But the hood support bracket and Rod won't fit :skep:Whats Up any body know :confused: EDMGUY.
[Modified by EDMGUY, 9:15 AM 10/12/2003]
Old Oct 12, 2003 | 11:17 AM
EDMGUY's Avatar
EDMGUY
Default Re: Problems with hood support?????????????? (EDMGUY)
Anybody Know where I could buy the updated hood rod and brackets :confused: Thanks EDMGUY
Old Oct 13, 2003 | 04:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
My '85 hood has provisions for the later style hood prop. But, I do know the '84 has a different hood. Do they claim it's supposed to be a bolt-on for your '84?
Old Oct 13, 2003 | 04:48 AM
EDMGUY's Avatar
EDMGUY
Default Re: Problems with hood support?????????????? (CentralCoaster)
That was my understanding and I already order the brackets and gas rod I will wait and see.EDMGUY
Old Oct 13, 2003 | 08:52 AM
LD85's Avatar
LD85
I had to take off the exsisting 1985 bracket and bolt on the new style of bracket then I trimmed off some of my bracket off and bolted it on over top of the new bracket.
I can emil you pics if you like.
Old Oct 13, 2003 | 09:53 AM
EDMGUY's Avatar
EDMGUY
Default Re: Problems with hood support?????????????? (ld85)
Hey thanks that would be a be help :hurray:
Old Oct 13, 2003 | 10:13 AM
LD85's Avatar
LD85
Check your email!
You need to take the bracket off that is currently mounted on a 45 Degree angle then put the new hinge bracket on in its place,,,, then hack saw the bracket you took off so it will clear the new hinge,,, and bolt it back ontop of the new hinge,,, clear as mud?
[Modified by ld85, 10:24 AM 10/13/2003]
Old Oct 13, 2003 | 11:39 AM
EDMGUY's Avatar
EDMGUY
Thanks ID85
that clears that up :thumbs: EDMGUY I let you know what happens.
Old Oct 14, 2003 | 11:35 AM
EDMGUY's Avatar
EDMGUY
id85 I hate to be a pain but can you send me some pics of the upper bracket and mount location if you have any Thanks EDMGUY
Old Oct 14, 2003 | 12:01 PM
LD85's Avatar
LD85
http://www.corvettemagazine.com/1999...ood/hoodp4.asp
[Modified by ld85, 12:08 PM 10/14/2003]
Old Oct 14, 2003 | 12:16 PM
EDMGUY's Avatar
EDMGUY
Thanks thats a big help. :thumbs: The 84 has a differnt lay out than a 85 but I can make work .Brackets will be here 10/16/2003.This is going to be soooo :cool: .EDMGUY
Old Oct 19, 2003 | 09:26 PM
EDMGUY's Avatar
EDMGUY
Ok completed the install on my 84 Corvette Had to extend the lower bracket
and reinforced the air intake for the TBI's.But was not to bad. And it woks so much better. thanks id85 for the help.
[Modified by EDMGUY, 7:32 PM 10/19/2003]
Old Oct 20, 2003 | 09:16 AM
LD85's Avatar
LD85
Nice job, this is a much nicer setup!
To Problems with hood support??????????????
