Ride height adjusting - Any suggestions?
Old Oct 13, 2003 | 12:48 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Ride height adjusting - Any suggestions?
My very stock 86 coupe sits with an obvious tail up stance.(about five fingers) I really like the looks of a C4 with about an inch of clearance between the top of the tire and wheel well opening. Or just about any Corvette for that matter....
Before I start making changes that I may regret, any suggestions the forum may offer are greatly appreciated.
[Modified by JrRifleCoach, 9:49 PM 10/12/2003]
Old Oct 13, 2003 | 07:57 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Ride height adjusting - Any suggestions? (JrRifleCoach)
MAD, Eckler's, etc. sell kits with longer rear bolts and smaller front spring "shims". The longer bolts allow you to adjust (drop) the rear to where you want it. The front is not only a PITA, but is a one shot deal (no adjustment). I have heard that there is up to a 3 inch adj. in the rear. The front is worth about 1.5 inches.
Old Oct 13, 2003 | 09:55 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Find some 9/16"x10" grade 8 bolts and stoffer lock nuts and replace the stock ones.
:cheers:
Old Oct 13, 2003 | 10:37 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Ride height adjusting - Any suggestions? (AGENT 86)
:iagree: Just check the rubber bushings you may need to replace them too.
Old Oct 13, 2003 | 12:47 PM
JrRifleCoach
Default Re: Ride height adjusting - Any suggestions? (Steel Blue 91)
Thanks all. There is an opportunity soon to start some mods that this car really needs. 1. Remove all three cats and replace the stock mufflers with something a little more aggressive. 2. There is considerable drive line shake at anyspeed above 75, so all six u-joints are due for replacement, and a loose rear whlbrng. 3. Dropping the tail should be easy enough while the rear is partially apart. Thanks for your input.. :cheers:
To Ride height adjusting - Any suggestions?
