xing wires
Old Oct 15, 2003 | 06:06 PM
1990CORVETTE's Avatar
1990CORVETTE
Default xing wires
Is it bad to cross spark plug wires? I thought i read on here once before that it was good..... Anyone help me in this matter :cheers:
Old Oct 15, 2003 | 06:39 PM
gstreak's Avatar
gstreak
Default Re: xing wires (1990CORVETTE)
With good wires it won't matter but, it is good practice to keep them apart wherever possible. This prevents shorting or cross-talk between the two. That is why the stock brackets and guides place the wires so neatly apart.
Old Oct 15, 2003 | 07:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
When two conductors run close and parallel to each other a sudden surge of current in one can induce a current in the other; this is the source of "cross-talk" between wires.
With spark plug wires this is only an issue with the #5 &#7 SBC wires due to similar phasing of the compression strokes.
As mentioned, performance wires are spiral-wound to virtually eliminate corss-talk. If running stock wires put #5 in the top separator slot and #7 in the bottom slot.
Old Oct 15, 2003 | 08:35 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: xing wires (65Z01)
I just put MSD Super conductors on my 85. while wiring the dist its almost impossible to NOT cross the wires as they come off the distributor.
To xing wires
