Backfire
Old Oct 27, 2003 | 10:52 AM
stevec's Avatar
stevec
Default Backfire
I took a ride yesterday in my '92 roadster and in the middle of a full throttle run, it backfired just after shifting into 2nd. I bought this car new and I've never heard it do that before! What are some of the reasons for a backfire?
Thanks,
Steve
Old Oct 27, 2003 | 12:49 PM
bogus's Avatar
bogus
Default Re: Backfire (stevec)
how many miles?
sounds like the opti is beginning to go south.
you might also need a tune up.
what is the maintenance history?
Old Oct 27, 2003 | 01:11 PM
Tom Piper's Avatar
Tom Piper
The backfire is a known problem -- GM issued a service bulletin on it.
Go to this site and search the page for "backfire." http://www.c4vettes.com/92sb.htm
Tom Piper
Old Oct 27, 2003 | 04:51 PM
stevec's Avatar
stevec
Default Re: Backfire (Tom Piper)
Tom Piper
I called a Chevy dealership here and the fix for the problem listed in the Service Bulletin is to replace the MEMCAL (EPROM). I was going to put in a power chip anyway so this is not real bad news.
Thanks!
Steve
Old Oct 27, 2003 | 05:03 PM
bstirn's Avatar
bstirn
If youre lucky it will fix it I have replaced every thing and still have a similar problem I am replacing valve springs & 1.6 RR this weekend . Mine backfires between the 1st and 2nd shift . Good luck
Old Oct 28, 2003 | 08:05 AM
stevec's Avatar
stevec
Default Re: Backfire (bstirn)
I checked the Service Bulletins for '93 and the bacfire problem wasn't listed. So it seems that according to GM, the chip replacement was the fix. But I'm hearing on this board that it's "maybe not"?
Steve
Old Oct 28, 2003 | 08:40 AM
bogus's Avatar
bogus
I am not entirely sure... Mine sometimes pops, but usually on trail throttle...
(mine is a 6spd)
I have no clue if mine has been done, either. I should have the VIN run through a computer to confirm WHAT has been done...
Old Oct 28, 2003 | 04:28 PM
bstirn's Avatar
bstirn
Default Re: Backfire (bogus)
It didnt work for me . I here the LT1 has weak valve springs.
To Backfire
