Cal"Crap" Error from ECM
Old Oct 30, 2003 | 08:42 PM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Default Cal"Crap" Error from ECM
In an '85 Vette that I have the computer is now throwing a "CalPak" error. It'll only show up on the scanner when the car is running. When it's running, it runs like CRAP! I un-did the battery and reconnected-- same thing. Then, I pulled out the computer, futzed around with the connectors, pulled out the chips (battery disconnected) and reconnected. Still the same code! Does this mean that the little chip inside the computer is fubar or is it the ECM itself? HELLLLP!
Old Oct 30, 2003 | 09:13 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Cal"Crap" Error from ECM (Aquaman)
? - any error codes at all...???
Per Tech Bulliten: GM: CALPAC is the small resistor-pack chip that is used for 'backup" or "limp" modes. The calpac is used by the ECM when it detects a sensor signal loss or sensor signal error. Under these conditions, the ECM used the fixed valued created by the CALPAC internal resistor as the default value for the specific sensor siggnal lost. This "substituted" signal allows the vehicle to operate in "backup" or "limp mode"
Note: the engine speed (RPM) sensor signal cannot be substitued, defaulted, or reproduced by the CALPAC. If the engine speed sensor signal is lost or inoperative..
* from that, it sounds like the ECM is FUBAR....*
Old Oct 30, 2003 | 11:08 PM
RogueVette's Avatar
RogueVette
Default Re: Cal"Crap" Error from ECM (vinnies87)
Thanks! Yeah, it does throw a code, but only while the car is running.. I forget off the top of my head but I seem to remember it being a code 52? Anyhow, the scanner says directly that it is a CalPak error. And the car only runs from mid to full throttle. Part throttle to mid throttle does nothing at all but un-choke the motor.
Old Oct 31, 2003 | 12:29 AM
vinnies87's Avatar
vinnies87
Well the CALPAC as in the prev post , definately points to the ECM unit:
Code 52: Check connection at the oil temp switch... replace switch...
Code 51: is Bad ECM or EPROM ....
Old Oct 31, 2003 | 09:32 AM
RogueVette's Avatar
RogueVette
52 in my book is the "CalPak" Code. This is an '85.
Old Oct 31, 2003 | 09:51 AM
scorp508's Avatar
scorp508
I had that one, dead ECM.
To Cal"Crap" Error from ECM
