Em LT guys
Old Oct 31, 2003 | 12:13 PM
MongooseLT4's Avatar
MongooseLT4
Default Em LT guys
I'm going to buy some EM Stainless longtubes and was wondering what list of things I need to get inorder for it to work.
Headered and X-pipe but what about O2sims where can I get those and is thier anything else you can think of, what about intermediate pipes from the headers to the X-pipe, or will the headers bolt right up to them?
Thank
Old Oct 31, 2003 | 12:22 PM
MongooseLT4
Default Re: Em LT guys (MongooseLT4)
I forgot to add that I'm not going to run cats
Old Oct 31, 2003 | 01:11 PM
tjwong's Avatar
tjwong
You should call Merle or Trevor at EM. They have 1.75" LT headers that are coated for about $750. Just as good as SS seeing how they are coated and less money. I didn't even inquire about the SS headers. I installed mine that are coupled to a 3" B&B Triflow cat back. I also got a set of Random Tech Bullet cats which are their high flow metallic substrate cats. No noticable reduction in noise at all with these cats and no reduction in flow whatsoever. These metallic substrate cats will flow around 600 CFM each.
I do have a Dr Gas X pipe in place of the resonator as well. If you have a 96 you will need to install the rear O2 sensors or a set of O2 sims to prevent a DTC or if you have the ability to edit the PCM programming you can delete the rear O2 diagnostics.
I may get a picture of my exhaust for you later today with the CATs in place.
Here is the thread where you can see the installation in my car.
http://forums.corvetteforum.com/zerothread?id=673730
The EM headers fit like a glove, very high quality header and I highly recommend them.
[Modified by tjwong, 10:17 AM 10/31/2003]
Old Oct 31, 2003 | 05:20 PM
ziggy57's Avatar
ziggy57
Default Re: Em LT guys (tjwong)
:iagree:
Same set-up minus the x-pipe! Works great
Old Oct 31, 2003 | 06:26 PM
silver & red CE's Avatar
silver & red CE
You can get O2 sims from: http://www.casperselectronics.com/aboutus.htm
Be sure to get the same O2 sims as used on a 96 Impala SS. Sometimes they send the wrong sims, the ones that fit an F-body won't work on a Vette.
Another alternative is to have you PCM reprogrammed to ignore the rear O2s
Eric
To Em LT guys
