weird crankcase pressure..
Old Nov 2, 2003 | 10:44 PM
Z06_BluByU's Avatar
Z06_BluByU
Default weird crankcase pressure..
my valve covers are leaking from all the center bolt hole penitrations.. AND FROM THE OIL FILLER CAP!!
I check the PCV valve and its free and looks good.. I've heard this can be caused my some cams.. (i just stroked the motor and added a cam similar tothe hot cam)
thanks for your input
Old Nov 2, 2003 | 10:45 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: weird crankcase pressure.. (BluByU)
BTW: i run 65+psi of oil pressure @ 200 rpm and more when the engine is cold..
Old Nov 2, 2003 | 11:45 PM
RonRed89's Avatar
RonRed89
Don't take this for anything more than informational since I am by no means a mechanic and I'm anxious to hear the real answer to this problem as well.
However, I noticed that in one of your other posts that you were running the Comp Cams 218/224 .495/.502 on a 112LSA.
I ran that same cam on my 350 on a 110LSA and never had crankcase pressure problems until I noticed just before my bearings spun that there was a good amount of oil leaking from the crankcase breather valve and the filler cap. I've never seen this happen to my car before that.
What does it mean? I don't really know myself. But I'm interested in hearing others opinions on why some cams might cause that.
Ron
Old Nov 3, 2003 | 01:16 AM
tjwong's Avatar
tjwong
Default Re: weird crankcase pressure.. (RonRed89)
Changing a cam won't cause excessive crankcase pressure that would cause an oil leak. Stroking an engine perhaps could, but only because the rings that were used had not seated properly causing excessive blow by and therefore causing the higher crankcase pressure.
Perform a leak down test and see what amount of cylinder leakage there is. That will give you a good indication of what is getting past the rings and into the crankcase.
Old Nov 3, 2003 | 09:43 AM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: weird crankcase pressure.. (tjwong)
could an intake leak on the lifter valley side possibly cause this also? What would be the proper diagnostic method?
1. inspect plus for oil fouling
2. Perform compression test
3. perform leakdown test
4. pull manifold and inspect for leakage (if compression test ok)
or fix rings in compression test not ok
can someone also explain to be the proper method of doing a leak down test?thanks!
Old Nov 3, 2003 | 10:04 AM
mistaben's Avatar
mistaben
were does one go to get the adapter to do a leak down test, btw?
Old Nov 3, 2003 | 02:07 PM
JAKE's Avatar
JAKE
The conduct a leakdown test you need an air compressor anda leak down tester.
Moroso and other sell them. The best ones consist of two guages, side by side.
You remove the spark plug, bring the piston to TDC, screw the hose end of the gauge into that cylinder, fire up the compressor and set the first gauge to the pressure recommended in the instructions that come with the tester.
You then read the second gauge and it tells you how much of the pressure is leaking by the rings, valves, gaskets, etc.
Jake
[Modified by JAKE, 1:08 PM 11/3/2003]
To weird crankcase pressure..
