torque converter selection
Old Nov 4, 2003 | 09:19 AM
WG87's Avatar
WG87
Default torque converter selection
I am doing a th350 swap and need to order a converter,I know there are at least a couple of of y'all going very quick with the th350 and would like to hear what you think.Right now I'm leaning toward 9-10 in @ about 3500,PTC or TCI.I have not talked to TCI yet but have allways had good results and dealings with PTC.I won't go as far as to say money is no object but a couple hundred bucks won't effect the selection.New setup will be-
383,afr 210 comp cnc,miniram,58mm tb,30# inj,tpis 700-703 solid roller,th350,3.45(I'm still looking for a D44),26in tires,car is-will be,pretty much full weight.BTW I suck at getting my thoughts to fingers to keyboard to screen so your patience is appreciated!
:cheers:
