Headlight not going down.
Old Nov 4, 2003 | 08:58 PM
GRNVNM93's Avatar
GRNVNM93
Default Headlight not going down.
My headlight all the sudden up and died on me today. It came up fine with no problems.. Then I go to turn the lights off and the driver's side light stays up... No clicking or clanking sound(like when the gears are stripped).. But there is a FAINT whinning sound(as if the motor is still running)... And if you play with the headlight itself, there is no slop in the rotation(as if a gear was rounded out)... So what could this lovely predicament indicate? Please and thank you in advance.
Old Nov 4, 2003 | 11:15 PM
GRNVNM93's Avatar
GRNVNM93
Default Re: Headlight not going down. (GRNVNM93)
Guess mine's the only one to ever do this? :crazy:
Old Nov 5, 2003 | 12:08 AM
jfb's Avatar
jfb
If the motor is still running, then you have a stripped gear and you need to remove the motor, buy a repacement gear and install it.
Old Nov 5, 2003 | 12:13 AM
GRNVNM93's Avatar
GRNVNM93
Default Re: Headlight not going down. (jfb)
I've had them replaced a couple years ago and the symptoms were much different.. The motor would make a heck of noise as the gears were freespinning. I'm not thinking its the gears as when the gears are shot the whole light assembly will easily spin(by hand).... :confused: :crazy:
Old Nov 5, 2003 | 12:15 AM
Bilyk's Avatar
Bilyk
have you checked the relays?
Old Nov 5, 2003 | 06:50 AM
GRNVNM93's Avatar
GRNVNM93
Default Re: Headlight not going down. (Bilyk)
If it were a bad relay, the motor would not even be running right? But the motor is making a noise...
Old Nov 5, 2003 | 12:40 PM
84BlackVette's Avatar
84BlackVette
8th Gear
I having the same problem. :confused:
Both go up, but driver side sticks like clockwork. Have to manually shut it if I drive the car at night.
Old Nov 5, 2003 | 12:47 PM
Unriced's Avatar
Unriced
Default Re: Headlight not going down. (84BlackVette)
Make sure the screws on the headlight housing cover aren't stickin out on ya...
That'll cause sticking headlight operation and a good amount of hood damage
if it's not taken care of. Screws coming loose are actually a common problem on
the earlier C4's. I'm not sure about the later years, though.
Old Nov 5, 2003 | 02:03 PM
GRNVNM93's Avatar
GRNVNM93
Default Re: Headlight not going down. (Unriced)
UPDATE!! :confused: :confused:
The freakiest thing happend.. Today i drove home from work with the lights ON and I went to turn them off and the bad headlight WENT DOWN on its own!?! :confused: I haven't tried to see if it'll go up or down now.. but whats up with that?? :confused: :confused:
Old Nov 5, 2003 | 09:17 PM
twogonzo's Avatar
twogonzo
I'm having same problem. Does it seem to stick in only cold weather?
Old Nov 6, 2003 | 06:28 AM
Brimis's Avatar
Brimis
It sounds like the relay or gear.
To Headlight not going down.
