4+3/ZF-6 Conversion
What would you do? Some say the 4+3 flywheel will still work, some others have found, like Bowtye, that there is insufficient pressure on the clutch when using the 4+3 flywheel. Its light and thinner than other flywheels so the clutch isn't clamped down with the necessary pressure needed to keep clutch from frying in a full blown
launch. Any suggestions? Use he 4+3 flywheel or go with another flywheel and pressure plate combo? I have the pressure plate, clutch, flywheel from the donor 1990 ZF-6. HELP! :cry
