85 383 into an Astro Van
Old Nov 16, 2003 | 08:55 AM
COMPVET's Avatar
COMPVET
Default 85 383 into an Astro Van
I am in the process of putting together a 383 with TPI from an 85 for my Astro Van tow vehicle. I have the complete harness from the 85. I understand the 85 compuer leaves a bit to be desired. With the TPI setup I got a couple different proms, one is for a basic 400 ci which I think should work fine.
Should I upgrade the CPU? If so to what? Is it a direct plug in, or does the newer one have different connections? will the proms I have work with the newer computer?
Pete
Old Nov 16, 2003 | 06:43 PM
SuperL98's Avatar
SuperL98
Default Re: 85 383 into an Astro Van (COMPVET)
I can't help you directly but,
These people probably can.
Their business is Astro V-8 conversion kits. http://www.racecraftconversions.com/p-rc4-a.html
I ordered their conversion manual a while back and I think it had a chapter on ECM's.
Can't seam to find it right now though.
Also is a V-8 Astro forum http://www.astrosafari.org/
I have a 95 AWD Astro and an old L98, was thinking about mating the two.
[Modified by SuperL98, 6:58 PM 11/16/2003]
Old Nov 17, 2003 | 03:22 AM
tjwong's Avatar
tjwong
You might want to update to a 1227165 ECM from a 86 and up TPI car. The data stream is much faster and makes for easier diagnostics. If that isn't a concern the older system will work fine.
Old Nov 26, 2003 | 05:46 PM
larryfs's Avatar
larryfs
go to astrosafari.net or .org maybe even .com
there's a whole bunch of small block vans running around.
while I keep mine STOCK !!
To 85 383 into an Astro Van
