Releiving fuel pressure
Old Nov 18, 2003 | 09:10 AM
SJLJ's Avatar
SJLJ
Default Releiving fuel pressure
How is that done? I want to change my fuel filter and would like some input on the subject. Any info appreciated
Old Nov 18, 2003 | 09:26 AM
vettefast's Avatar
vettefast
Default Re: Releiving fuel pressure (SJLJ)
You are going to loose a small amount of fuel when you change the filter. Anything you do to releive the pressure is not worth the small amount of fuel that run out when making the change.
Old Nov 18, 2003 | 09:31 AM
chucks88's Avatar
chucks88
Default Re: Releiving fuel pressure (vettefast)
With the engine running pull your fuel pump fuse until the car stalls. Remove your gas cap and let it sit over night if you can.
Old Nov 18, 2003 | 10:52 AM
Unriced's Avatar
Unriced
I would be prepared for some fuel coming out.
I just did my fuel pump and ran the car dry
and there was still plenty of gas under pressure
in the feed line, so don't assume and keep your face
away from where you could get sprayed...
I've seen someone get gas in the eyes before..
ouch... HTH
Old Nov 18, 2003 | 11:52 AM
ToniH's Avatar
ToniH
Default Re: Releiving fuel pressure (chucks88)
Correct, also relieve the pressure from the fuel rail valve. It is on the passenger side. Use a rag to catch the small amount of fuel that bursts out from the valve.
ToniH
Old Nov 18, 2003 | 11:53 AM
Steel Blue 91's Avatar
Steel Blue 91
:iagree: Just remember that will just relieve the pressure. There will still be fuel in the lines and the filter is the lowest point of the system. You will get some drainage when you crack the lines at the filter.
Old Nov 18, 2003 | 01:15 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Releiving fuel pressure (Steel Blue 91)
:iagree: good luck
Old Nov 18, 2003 | 02:43 PM
SJLJ's Avatar
SJLJ
Default Re: Releiving fuel pressure (vinnies87)
Thanks to all. Once again the forum comes thru.
Old Nov 19, 2003 | 12:35 AM
MrRenoman's Avatar
MrRenoman
Yup! Even if you relieve the pressure on the fuel rail, the second you crack open the fitting on the fuel filter, the gas will start to siphon out of the tank. Relieving the pressure keeps fuel from spraying out all over the place but won't keep the fuel from siphoning out of the tank. If you left the line disconnected it would probably drain your entire tank.
Old Nov 19, 2003 | 10:20 AM
darkred91's Avatar
darkred91
Default Re: Releiving fuel pressure (MrRenoman)
:iagree: It's not hard have a rag handy Good luck...................
To Releiving fuel pressure
