LT1 Engine Vibration: Balancer, Flywheel, Missing???
At this point, I am thinking it might be the harmonic balancer. From visual inspection (without removing it from the crank hub), it looks to be in acceptable condition. The car only has a little over 40k miles.
Can these balancers be bad without any visual signs that they have deteriorated? The rubber piece between the inner and outer sections looks to be in good condition. Should I go ahead and pull the balancer off of the hub to give it a closer look?
Aside from the balancer, I'm not sure what else it could be. I guess it could be the flywheel, but I would imagine I'd have more noticeable symptoms with a bad flywheel. I do notice that occasionally when I have the clutch out in neutral, there is a lot of clacking and rattling coming from the ZF. I know some is normal, but occasionally it does sound worse than normal.
The other thing I've considered is a misfire condition at higher rpms. The plugs and wires are A/C Rapidfires and Taylor, and they are all new, so I think this would be the least likely scenario.
This is really puzzling to me. Any help/experience you guys have to offer would be greatly appreciated :cheers:
KDD
KDD
No modification done to the engine that I know of. It has new plugs and wires, and a custom muffler shop exhaust system (stock manifolds with no cats, though).
[Modified by HammerDown, 11:30 AM 11/21/2003]
I am very curious to know the issue.....did it start after the exhaust had been installed???? Maybe wire not on all the way????? plug with closed gap????
[Modified by buell_freak, 1:09 PM 11/21/2003]
As far as wires or exhaust, I am really trying to remember when this whole thing started. I wanted to say it started after the exhaust work, but I can't be sure. I spent a good 30 minutes under the car last weekend to check for clearance around the exhaust system, and there was plenty. No contact whatsoever. As far as wires and plugs go, I did the plugs before the exhaust, and the wires afterwards. Again, precisely remember when this started happening, or when I actually noticed it happening.
I think I am resolved to take the balancer off next, but other than visually inspecting it for obvious deterioration, I don't know what to do after that.
Even if you have a missfire, reving the engine up would smooth it out. If its a serious engine mis-balance the vibration would be felt regardless. Double check your firing order and make sure that there isn't any crossed plug wires. If your plug wires are stock, they are numbered.
[Modified by tjwong, 11:29 AM 11/22/2003]
I doubt I have crossed plug wires. I have been driving it now for over three months since I changed them, and generally you can tell right away when the plug wires are crossed. If you're saying that a misfire condition would smooth out when the engine is revved, then this kinda points to a balancer or flywheel problem.
Can a sticking lifter cause a similar vibration at higher rpms?
To characterize the vibration I'm talking about, it's not a "hard" vibration, more like sitting in one of those heated vibrating chairs at Brookstone.
[Modified by HammerDown, 1:46 PM 11/22/2003]
[Modified by HammerDown, 1:47 PM 11/22/2003]
If your engine does have a mis-fire a noise could come from the DM flywheel. As it does have about 30mm of movement to dampen the gear clatter from a ZF transmission. If the flywheel is worn to a point where the range of movement is > 35mm it could make a lot of noise regardless if there is a misfire or not. As you have said you have been driving the car for over 3 months and if you had a engine miss your fuel milage would be bad and performance would also suffer severly.
I had considered the flywheel being the source of the problem; however, I wouldn't think the flywheel would be bad after only 41k miles. If so, that's got to be some kind of record for shortest life of an OEM flywheel.
I sure hope it's not the flywheel. $$$$$
