Brake Bleed Sequence for 87?
Old Nov 21, 2003 | 06:13 PM
YorkL8apex's Avatar
YorkL8apex
Default Brake Bleed Sequence for 87?
Anyone know the proper brake bleed sequence for doing a flush on an 87? also is there an easy way to flush the ABS?
:confused:
Old Nov 21, 2003 | 06:31 PM
rcolling's Avatar
rcolling
Default Re: Brake Bleed Sequence for 87? (York67vette)
I am not sure about flushing the ABS but the correct way to bleed brakes is always farthest from the master cylinder to the closest.
In the Corvette the front lines are separate from the rear lines so technically it would not matter you did fronts and then rears but for consistency I always bleed
Right Rear
Left Rear
Right Front
Left Front.
Old Nov 21, 2003 | 08:59 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:D Tony
If you flush the entire system, you are also flushing ABS
Start at right rear, move to right front, then left rear and left front
I use two big containers (16 oz each ?) Dot 4.
You can "gravity bleed" but that takes a long time or you can get a vacuum pump, around $ 40 or you can have Kathy work the pedal :D
:seeya
:steering:
Old Nov 21, 2003 | 09:22 PM
scorp508's Avatar
scorp508
Default Re: Brake Bleed Sequence for 87? (jackdaroofer)
Per '87 service manual...
RF
RR
LR
LF
Old Nov 22, 2003 | 01:15 AM
rcolling's Avatar
rcolling
Default Re: Brake Bleed Sequence for 87? (scorp508)
RF
RR
LR
LF
Interesting that it should be different for different years.
I just double checked the 96 manual and it says
"RR, LR, RF, LF"
I no longer have the '86 manual but I know I bled it in the same order.
Old Nov 22, 2003 | 03:16 AM
tjwong's Avatar
tjwong
Default Re: Brake Bleed Sequence for 87? (rcolling)
Traditionally you always bleed the point farthest away from the master cylinder. Saying this it would be as stated above:
RR, LR, RF, LF
Old Nov 22, 2003 | 08:21 AM
MITCH's Avatar
MITCH
buy the speed bleeders i did my my 1987 the in about 1/2 hour the hardest thing was to take the rear wheels off the car. these things work great.
mitch :cheers:
Old Nov 22, 2003 | 08:31 AM
Corvette0096's Avatar
Corvette0096
Default Re: Brake Bleed Sequence for 87? (tjwong)
RR, LR, RF, LF
:iagree:
Old Nov 22, 2003 | 09:55 AM
scorp508's Avatar
scorp508
Keep in mind all lines first go to the ABS controller behind the driver seat and then to their respective wheels.
Old Nov 22, 2003 | 06:37 PM
NoWorries's Avatar
NoWorries
:yesnod: RF, LF, RR, LR
In case you do somehow introduce air into the system, the ABS bleed is on the rear of the ABS module, which is in the compartment behind the driver's seat. You have to go from under the car to get to it. But unless you get air in the system, an ABS bleed is not necessary.
Old Nov 23, 2003 | 12:36 PM
mr.beachcomber's Avatar
mr.beachcomber
Default Re: Brake Bleed Sequence for 87? (NoWorries)
I agree that the factory manual sequence is best unless you've disconnected the ABS like Jeff did in his '89. :thumbs:
I just wanted to point out that the '86-'91 ABS units don't have a factory installed bleeder. (The '92-'94 units and '92-'95 ZR-1 controllers do have a bleeder fitting. The non-ZR-1 '95 & '96 ABS units require a scan tester for bleeding.) The '86-'91 ABS units required a special tool to cycle them (just like at startup) to effectively purge the unit of air.
If, for whatever reason, you introduce air into the ABS system, try this:
1. Bleed the rest of the system until no air is apparent in any caliper.
2. Start the car and drive forward/backward several times to active the ABS system. I use six cycles (three forward/three backward).
3. Re-bleed all calipers. Any air trapped in the ABS should be now in the brake lines leading to the calipers.
Hope this helps! :seeya
Old Nov 23, 2003 | 07:35 PM
YorkL8apex's Avatar
YorkL8apex
Default Re: Brake Bleed Sequence for 87? (mr.beachcomber)
THanks Greg and all you other guys!!! :blueangel: :blueangel: I've got a 91 Service Manual and looks like the 87 uses that sam e "official" sequence. I always seemed to need to activate the ABS on the 91's to really get all the old gunky fluid out of the system.:mad
I'm headed to Roebling Road next weekend so I guess I'll get a chance to activate it there :eek:
As always thanks for the input guys :flag
To Brake Bleed Sequence for 87?
