OUCH! Help
Old Nov 27, 2003 | 03:26 PM
TuffShift's Avatar
TuffShift
Default OUCH! Help
:confused: :banghead: :seeya in that sequence.
[Modified by TuffShift, 11:21 PM 11/27/2003]
Old Nov 27, 2003 | 06:28 PM
redfast's Avatar
redfast
Default Re: OUCH! Help (TuffShift)
:iagree:
Old Nov 27, 2003 | 07:40 PM
neverendingproject's Avatar
neverendingproject
Default Re: OUCH! Help (redfast)
:confused:
Old Nov 27, 2003 | 07:42 PM
hngacurv's Avatar
hngacurv
Default Re: OUCH! Help (neverendingproject)
:confused:
Old Nov 27, 2003 | 09:20 PM
Unriced's Avatar
Unriced
He musta got confused, banged his head, and feels better about it now..
Take two Tylenol, and call us in the morning... :crazy:
Old Nov 27, 2003 | 09:29 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You must be pizzed about your fine weather there. :jester
Old Nov 27, 2003 | 11:00 PM
TuffShift's Avatar
TuffShift
Default Re: OUCH! Help (corvetteronw)
The end of one of my my roller rocker arms snapped off today and I don't know why. No I am not a happy camper.
Can I put one of the "factory ones" on in its place so I can get the vette back to the shop that installed them, providing they are all 1.5 rockers?
The sucky weather is nothing compared to this! :mad :banghead:
Old Nov 28, 2003 | 01:56 PM
TuffShift's Avatar
TuffShift
Well as a result of all the helpful comments and suggestions I got here, I managed to determine that the spring retainer came off of the valve stem and allowed unrestricted movement of the spring and intake valve at high rpms, which sheared off the roller end of the rocker arm. I am missing one half of the two-piece tapered retainer and must assume it managed to fall into the valley area beneath the intake manifold (where else could it have gone?)
The valve stem is bent, which means I'll have to pull the head, which means I'll have to pull the intake, which means I'll have to pull........
At least I'm glad it happened now and not in the middle of the summer cruising season. Although I'd much rather it didn't happen at all.
I want to thank you all again for being so helpful through this ordeal. I dunno know what I would've done without ya. Probably would had to of figured it out myself.
Hey, come to think of it, that is what I did. How 'bout that. I didn't need any of you guys' non-help afterall.
Old Nov 28, 2003 | 02:10 PM
ittlfly's Avatar
ittlfly
That's OK. If you do need help, we are still here. :D
Old Nov 28, 2003 | 03:03 PM
Caboboy's Avatar
Caboboy
I must've been doing something Thanksgiving nite that precluded my responding to the post where you actually described any specifics......sorry 'bout that :p:
Now that I read the issue, I'd suggest you talk with the shop that did the rockers. A retainer failure is just too coincidental after having valvetrain work done. Best of luck to you, this could have some piston implications as well....... :(
Old Nov 28, 2003 | 04:23 PM
TreyZ28's Avatar
TreyZ28
and all this time i thought u were confused :confused: , so you banged your head against the wall :banghead: and knocked yourself out :seeya
Old Nov 30, 2003 | 04:51 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
And your question is?
:confused: :confused:
Old Nov 30, 2003 | 11:39 AM
TuffShift's Avatar
TuffShift
Default Re: OUCH! Help (oldace84)
It was cancelled due to lack of interest. :sleep:
To OUCH! Help
