C5 brakes
Old Dec 1, 2003 | 08:09 AM
Lord Odin's Avatar
Lord Odin
Default C5 brakes
What's the big deal about these brakes that I keep seeing people wanting to upgrade to? Are they superior to aftermarket C4 brakes? :confused:
Old Dec 1, 2003 | 08:46 AM
vader86's Avatar
vader86
Default Re: C5 brakes (Lord Odin)
Better stopping power than the J55s or stock brakes.
Much cheaper than a Baer or Wilwood setup, but are not as good as those racing setups.
Plus the calipers have "corvette" written on them
Old Dec 1, 2003 | 11:38 AM
STL94LT1's Avatar
STL94LT1
One problem with the C5 brakes. You can't run them with your stock saw blades, without wheel spacers.
Old Dec 1, 2003 | 06:05 PM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
Default Re: C5 brakes (STL94LT1)
I would be more worried about the pad/rotor setup, in my opinion that will make a bigger difference than different calipers. :D
Old Dec 1, 2003 | 06:13 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: C5 brakes (96CollectorSport)
:cheers: I believe C5 pads are larger than even C4 j55.
I have the C5 conversion on the front and the DRM proportioning spring working on the rear and it is AWESOME! SOTP, stopping from 60 to 0 is down to around 110 to 120 feet. More imprtantly, braking going into turns is dramatically improved. I can carry speed much, much further into turns, then brake and steer.
Didn't put the C5 rears on since the only real difference is the thickness of the roter and, the emergency brake system is completely different
:seeya
Old Dec 2, 2003 | 04:03 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
I'm sure I'll be in the minority, but over rated.
Old Dec 2, 2003 | 05:03 AM
DON M's Avatar
DON M
I have found them to be quite an improvement. :thumbs:
Old Dec 2, 2003 | 08:20 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: C5 brakes (Jeffvette)
Yep.........
Old Dec 2, 2003 | 09:36 AM
Zix's Avatar
Zix
I just upgraded my Grand Sport brakes on my LT4 CE to the C5 front rotors and alipers and there is a HUGE difference. The stopping power is well beyond anything I had before, and the brake fade is way down as well. Plain and simple, the C5 caliper is a much better design with more sweep area. And for the cost it's one of the best upgrades you can do for the money.
Old Dec 2, 2003 | 09:46 AM
QuikZilver's Avatar
QuikZilver
Default Re: C5 brakes (Zix)
Check out Superior Chevrolet for the parts to do the conversion: http://www.superchevyparts.com
They have everything at great prices!! All you need after getting those parts are the adaptors. I have the ones forum member edsalinas sells. Great quality!! And, you help support a forum member. :)
:cheers:
Old Dec 2, 2003 | 10:00 AM
Goody's Avatar
Goody
Well the big deal is that they don't cost over $2000 like most of the other race setups will cost. They aren't aftermarket either. Well, the adapter is but that is it. All other parts can be bought from any GM dealer in the US and you have a multitude of choices for brake pads. You can have standard GM, premium aftermarket, ceramic, carbon metallic and etc. Plenty to fit your needs and budget.
Will it stop as well as the Stoptech, Willwood, or Brembo setups? NO WAY!! But I'm not spending that amount of money on parts and pads either. Race systems are made much better and are suited for racing. I don't much race my car, but I do autoX. I'll see if there is a difference when I go do that later this month. A tenth of a second will make them worth it to me for sure.
The next time you go buy a C4 13" rotor for close to $100, I will be buying a pair of front rotors for close to $50 from NAPA (although the jury is still out on their rotors in my mind). I can get a pair of rotors from Superior for $100 + ship.
And another reason I got them was that they do look :cool: behind my chrome Z06 wheels. :D
Old Dec 2, 2003 | 10:30 AM
Lord Odin's Avatar
Lord Odin
Default Re: C5 brakes (Goody)
Will the C5 brakes fit at all under the sawblades? Or would I be forced to go aftermarket?
Old Dec 2, 2003 | 10:36 AM
xlr8nflorida's Avatar
xlr8nflorida
I need the brackets, who sells them.
I checked with a company in Tampa and they wanted like $450 for two brackets and some hardware.
Seemed way pricey to me.
I have the red Z06 calipers and eradispeed two piece rotors that were on a C5.
Additionally, I can't use the rear rotors (I've been told this) so I'm trying to figure out a way so all 4 rotors match one another or at least look similiar.
Also I cant use the Z06 caliper so I thought I would just get a spare ZR-1 caliper and paint it red to match the fronts.
Any suggestions would help as these rotors have sat in my garage over a year.
Old Dec 2, 2003 | 10:39 AM
vvv90's Avatar
vvv90
I have the Zr-1 5 star AFS 9.5" rims....I'm guessing I'll be alright...right?
Can someone list out ALL the parts needed with prices? I guess I have a new project. :D
[Modified by vvv90, 9:39 AM 12/2/2003]
Old Dec 2, 2003 | 10:44 AM
edsalinas's Avatar
edsalinas
Default Re: C5 brakes (vvv90)
Here's the part numbers, and what I paid 4 them:
ZO6 (painted red) caliper, G.M. 88895128 & 29, I paid $81.37 each. The plain C5 caliper p/n is 12530682 & 83, should be cheaper, but they're not. ?
Rotors, A.C. Delco p/n is 177-852 & 53, I paid $53.06 each.
The anchor, or hanging bracket (caliper mount) dealer only, p/n 12455799 (both sides), I paid $27.47 each.
Guide pin (4 req'd) G.M. p/n 12530697, I paid $3.63 each.
When you buy your pads, they should come with a "hardware kit", with 4 small rubber boots as well. If not, that G.M. p/n is 18039816, I paid $16.47 for one, that should be all you need 4 the entire install.
Old Dec 2, 2003 | 10:45 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
I know a lot of guys run without the spare tire anyway and so it's a moot point for them but does this mean that the spare will no longer fit either?
Old Dec 2, 2003 | 10:46 AM
edsalinas's Avatar
edsalinas
They will but you'll need at least a 1/2 inch wheel spacer........ :mad
To C5 brakes
Old Dec 2, 2003 | 10:49 AM
edsalinas's Avatar
edsalinas
Default Re: C5 brakes (tobijohn)
Good question, I don't know?????
:confused:
Old Dec 2, 2003 | 10:52 AM
vvv90's Avatar
vvv90
That's a good question! :confused: I run with my spare and have NOOO plans on removing it.
BTW: Is there any difference between Z06 and regular C5 brakes? It appears that the pads and rotors are the same :confused:
Old Dec 2, 2003 | 11:02 AM
edsalinas's Avatar
edsalinas
The Z06 & regular C5 calipers are the same, only the Z06's are painted red...
