First off, for an LT1 it is not a 4.1" bore with a 3.875" crank stroke. It is a 4.030" bore with a 4" crank stroke. You would have to do a LOT of work to an LT1 block to get it to a 4.1" bore as most will not even bore out to +.060".
The problem with them is increased piston speed, shallow piston ring height, and it can be expensive to machine the block for the 4" stroke.
:iagree: Chris, is yours a 3.875 with a 4.040 bore?
Yep,it wasn't cheap to have it clearanced for a 3.875 crank either. :steering:
TPIS did build a 409 CI LT-1 in 1997 and they did bore the block .100 over to arrive at a 4.1 bore and 3.875 stroke for 409 displacement. I do not know how they were able to bore the block .100 over but that was the 409 combination that they built. Maybe they filled the block part way with block filler?
I don't think most 350s will take that much over-bore. Possibly an after-market, or GM performance block? Block filling is usually only up to the bottom of the water-pump holes at most, and is used to strenghten the block, keep the bores round, prevent ring flutter,crank-walk and such. I think if you filled the whole block, there would be no cooling.
I'm in the middle of building a 415" LT1 right now for a friend's T/A... I swore I'd NEVER build a 350 based motor with a 4" stroke because of the clearance involved and the poor rod/stroke ratio... But here I am doing it anyway.
I've had to clearance the **** out of the block; so much that I wasn't comfortable milling as much out as I did so I put a short fill of Hard-Blok in the very bottom of the block for extra "insurance." Reduced base circle cams are a must to prevent rod contact with the lobes. The rod/stroke ratio is a poor 1.46:1 and I'm of the opinion that the piston velocity will be very high...
-Jeb
using the lunati pro-mod rods for my 409 with my 4" stroke didn't require nearly as much clearancing as i thought it might, and certainly not as much as what you guys sound like you had to do. i think they are great for the 4" stroke applications.
:D Sonny... Didn't you ask me to build a 409 for you awhile back?? And I told you "no way in hell" I wanted to do a 4" stroke in a 350 block?? And here I am building one anyway... :lol:
-Jeb
Just to clear things up, it is a 4.100 x 3.875 motor. It is not a stock block, it is a GM race block that was available for the World Challange series. This has a lot more meat to be able to do the 4.100 bore.
Best to just do a 396, and leave room for a later re-bore to go to a 402. IMO.
Yes it looks like it would work. You don't have to clearance this block as much for the 3.875 stroke as you do with a stock block. So I am sure it will go.
