Code 25 and 74 on a 91???
Old Dec 7, 2003 | 10:59 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Code 25 and 74 on a 91???
On my drive back from the ClubVette Christmas party, the SES light came on and stayed for approx 10 minutes then went out. I was on an interstate highway, running at 65 to 70 mph. When I checked the codes this morning, they showed as history. Two questions:
1. Code 25 is high intake air temp. Outside temp was 37*. Is that possible?
2. What is code 74? I can find no reference to it.
Any advice appreciated.
Old Dec 8, 2003 | 07:56 AM
Steel Blue 91
Default Re: Code 25 and 74 on a 91??? (Steel Blue 91)
Anyone?
Old Dec 8, 2003 | 09:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Code 25=Put ohm meter on sensor, Must NOT read 0 ohms or infinite ohms.
Check wiring to IAT
Code 74=high alcohol content, Sleep it off :D
:cheers:
Old Dec 8, 2003 | 10:14 AM
ittlfly's Avatar
ittlfly
Default Re: Code 25 and 74 on a 91??? (AGENT 86)
You didn't say if there was any noticable change in performance...engine speed, missing etc. Was it just the SES llght ? The fact it went out, indicates a soft code. It could be the sensor went out of range for a few but returned to its' normal. If there are no other symptoms, I'd clear the codes and see if it returns.
Old Dec 8, 2003 | 10:31 AM
Steel Blue 91
Default Re: Code 25 and 74 on a 91??? (ittlfly)
No noted change in performance when the SES light came on. I cleared the codes yesterday and have had no returns. Just curious as to the code 74.
Old Dec 8, 2003 | 05:47 PM
ittlfly's Avatar
ittlfly
Hmmmm code 74? That's a new one on me. :confused:
To Code 25 and 74 on a 91???
