52MM Throttle bodies
Old Dec 19, 2003 | 01:35 AM
tjwong's Avatar
tjwong
Default 52MM Throttle bodies
Someone on the forum was rebuilding 48mm TB into 52mm bodies, can someone provide a contact.
Old Dec 19, 2003 | 06:24 AM
Dark-Knight's Avatar
Dark-Knight
Default Re: 52MM Throttle bodies (tjwong)
LPE does the conversion, damn fine work too!
Old Dec 19, 2003 | 06:47 AM
STL94LT1's Avatar
STL94LT1
Here you go Tom.
Dave Koldos dkoldos@ameritech.com
Old Dec 19, 2003 | 07:46 AM
chucks88's Avatar
chucks88
Default Re: 52MM Throttle bodies (STL94LT1)
I had Dave rebuild mine and port it to 52mm. He does good work :thumbs:
Old Dec 19, 2003 | 09:35 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
TJ, Dave did mine also. :steering:
Old Dec 19, 2003 | 12:11 PM
JB666's Avatar
JB666
Default Re: 52MM Throttle bodies (Ramrod92)
Correct me if I'm wrong, but with nothing more then a K&N/open filter& Flowmasters, this 'mod' wouldnt' do me much good would it?? Except maybe helping it breath for FUTURE mods......
Old Dec 19, 2003 | 07:35 PM
BAM92's Avatar
BAM92
Default Re: 52MM Throttle bodies (Jbaker)
:iagree: Dave. I would have him do mine before spending money on an aftermarket one. He is how I found the forum in the first place. When I was inquiring about him boring out my tb he sent me to a post on here. Word of mouth is the best. :thumbs:
Old Dec 19, 2003 | 08:41 PM
atotalnincompoop's Avatar
atotalnincompoop
Here you go Tom.
i've only heard good things :cheers:
Old Dec 19, 2003 | 09:21 PM
Dan Parker '96's Avatar
Dan Parker '96
I went the David Koldos route on a TB off Ebay. Totally worth the effort. Great quality. On an LT4/Hotcam conversion (through stock exhaust) I can quantatively report that you will see a pressure increase at the intake manifold.
Whether or not the engine makes use of that pressure increase is not clear (didn't pigeon hole that performance aspect at the last dyno session.... it was primarily for O2 with N2O). But data logging shows a consistent increase in manifold pressure.
Regardless, you'll like what David can do with a stock TB.
Old Dec 19, 2003 | 11:54 PM
John Row's Avatar
John Row
I think Bogus did back to back dyno's with a bigger diameter TB. It did make a difference on his modded engine. A lot of people, including me, bet he wouldn't see a difference.
Old Dec 20, 2003 | 01:40 AM
tjwong's Avatar
tjwong
Thanks to all that has replied. I got a hold of Dave today via email so I was able to forward his message to my friend here that is wanting a 52mm conversion done on his stock TB.
Old Dec 20, 2003 | 03:53 PM
ninetyfivevette's Avatar
ninetyfivevette
With the mods listed in my sig, is it time for a 52mm throttle body? I got the SLP Claw as a christmas gift and I could not notice a gain, so I was thinking perhaps the throttle body is too restrictive.
Old Dec 20, 2003 | 04:57 PM
tjwong's Avatar
tjwong
Default Re: 52MM Throttle bodies (ninetyfivevette)
If I was you I would go go for it. Having the Hot Cam and EM LT headers let her breath a bit easier. I am sure that you will have some gains from the midrange and up. If you can get a before and after dyno run. If you are in the Seattle area I am sure there are a few dyno shops around. One who is south of you in the Tacoma area is Blood Enterprises, he has a Mustang Chassis dyno.
Old Dec 21, 2003 | 01:11 AM
comp94's Avatar
comp94
how much does dave charge to port out a stock 48mm to a 52mm
To 52MM Throttle bodies
