Exhaust
Old Dec 19, 2003 | 07:54 PM
CaliforniaVette's Avatar
CaliforniaVette
Default Exhaust
Hey im new to this site, i have a 96 LT4. Im goin to be getting exhaust soon so i was thinking get that mid chamber removed and run straight pipes to some flowmasters, and i probably will get a cutout as well. does anyone have flows and are they impressed? another question is should i get a pipe welded on that connects the dual exhaust ? i think its called an Xpipe or crossover tube, is it to even flow or exhaust pulses?? BTW i can get this all done for 350 dollars.. :)
Old Dec 19, 2003 | 08:19 PM
86PACER's Avatar
86PACER
Default Re: Exhaust (CaliforniaVette)
:seeya :D
Welcome to the forum!
Old Dec 19, 2003 | 08:38 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Exhaust (86PACER)
welcome :seeya
Old Dec 19, 2003 | 10:10 PM
Dark-Knight's Avatar
Dark-Knight
You'll get lots of help on this one. Remove the reasonator, under the passenger section, replace with an x-pipe. Then depending on how loud you want to go replace the muffs with either Corsa's, Magnaflows, muff elims, etc.
Eventually, headers are a must...
:seeya
[Modified by Beautiful Beast, 9:11 PM 12/19/2003]
Old Dec 19, 2003 | 10:14 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Howdy :cheers:
Stick around and read alot. There is a plethra of information floating around these posts. Bad news is; the search engine is broken, good news is; you'll find more info here than you can imagine.
Never hurts to ask a question. That is of course, you know how to release your parking brake. :lolg: (You had to be there)
[Modified by JrRifleCoach, 11:46 PM 12/19/2003]
Old Dec 20, 2003 | 02:13 AM
CaliforniaVette
Default Re: Exhaust (Beautiful Beast)
yes i would love a set of ceramic long tubes! but im just starting off..... for now!
Old Dec 20, 2003 | 02:43 AM
tjwong's Avatar
tjwong
Your resonator is what you are thinking of removing. One note about that resonator I doubt there is going to be any gains to be had by removing it. Other than gaining a lot of in cabin resonance especially if you are thinking about installing a set of Flowmasters. The resonator is a 2.75" straight through core muffler. There is little to no backpressure from there. Just adding a set of rear mufflers will be the best thing you should do and save yourself the resonance problem. Now if the whole idea is to make the car loud then by all means remove it. I think Flowmaster makes a set of rear mufflers for the LT1 C4s. In any case any competent muffler shop should be able to install a set of 3" single inlet/dual 2.50" outlet mufflers with a set of additional chrome tips doing within your budget should be close.
Welcome to the forum as well! :seeya
[Modified by tjwong, 11:44 PM 12/19/2003]
Old Dec 20, 2003 | 03:43 AM
OneRedLT4's Avatar
OneRedLT4
I did close to what you're talking about, except I went with Magnaflows. I don't like the way flowmasters sound (everything sounds like everyone else's 5.0 mustang) :nonod: . However, after having the magnaflows put on, I wasn't happy with how quiet it was, and immediately had the resonator pulled. It made a significant volume difference...for the good. If you do a search, you can find some sound clips of member's cars with diferent set ups. You might find something else you like. Good luck and welcome.
Mine: Magnaflows - no resonator (Please excuse the steam and throwout bearing)
[Modified by OneRedLT4, 2:44 AM 12/20/2003]
[Modified by OneRedLT4, 2:45 AM 12/20/2003]
Old Dec 20, 2003 | 09:21 AM
dwestsr's Avatar
dwestsr
Default Re: Exhaust (OneRedLT4)
Hey, no offense but yours sounds more like a Mustang than my 86 with Flowmasters Cat back. I like the Flowmasters better although there is a bit of resonance under mild acceleration but very quiet at cruise. :cheers:
Old Dec 20, 2003 | 09:26 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The search engine isn't broke, just not working to 100%(you have to know exactly what you are looking for and fill in as many details as possible).
I wouldn't put cutouts on a stock vehicle, it will make the car sound like crap and only slow you down(how do I know?because I drove around with an open exhaust and it was a slug).
Cheapest thing to do is to leave the center resonator and cut off the rear mufflers and replace with straight pipes and reuse your tips. That will give you a great sound(slight loss in power, but not enough to really make a difference). But your idea of an X pipe and Flowmasters is good, but it will be very loud.
Old Dec 20, 2003 | 02:21 PM
CaliforniaVette
Default Re: Exhaust (Mr Mojo)
How much of a price difference is Magnaflow compared to FLowmaster? yea i dont think im goin to go with a cutout... thats more of a Camaro thing i guess! haha :chevy
To Exhaust
