SYS Error Driving Me Nuts!
Old Dec 22, 2003 | 02:18 PM
1BAD92VETTE's Avatar
1BAD92VETTE
6th Gear
Default SYS Error Driving Me Nuts!
After installing an aftermarket radio in my 92 Vette, I keep getting a SYS error flashing 3 times by the MPH read-out. Flashes 3 times and then goes away but returns after a little while. Help Please.
Old Dec 22, 2003 | 02:23 PM
Red Dwarf's Avatar
Red Dwarf
Default Re: SYS Error Driving Me Nuts! (1BAD92VETTE)
Try the Audio section. There was something on this problem a couple of weeks ago.
Old Dec 22, 2003 | 03:03 PM
J Z06's Avatar
J Z06
Heh
I Had a "mild" system done in '98. The sys light still blinks to this day. I'm sure there's a quick fix...somewhere. I remember reading about it.
Old Dec 22, 2003 | 03:38 PM
Goody's Avatar
Goody
Default Re: SYS Error Driving Me Nuts! (Jay 383)
Involves adding a 1k ohm resistor to a wire, I'm just not sure where.
Old Dec 22, 2003 | 06:40 PM
VERLYN's Avatar
VERLYN
Cruising
Let me know what you find out. I just removed my factory BOSE, sent it in for rebuild. I re-installed it, but now I have the SYS flash up intermitantly where the MPG also reads out. I also have one rear speaker/amp that I had to send back in, and it lasted all of about 15 minutes before it went again. I could smell it when it went (burnt). All other speakers work, but now the SYS light comes on. I disconnected the bad speaker and am running on the other three. I haven't driven it since I disconnected the one. Any other ideas? Thanks in advance. :confused:
Old Dec 22, 2003 | 07:07 PM
1BAD92VETTE
6th Gear
Default Re: SYS Error Driving Me Nuts! (VERLYN)
http://www.corvetteforum.net/c4/dave8476/index4.shtml
The above link should fix this problem.
To SYS Error Driving Me Nuts!
