Removed Air Pump............ Questions
Old Dec 31, 2003 | 08:35 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Removed Air Pump............ Questions
Happy New Year :seeya
Anyone got pics of everything they removed along with the pump ?
Tell me everything you know :jester
:cheers:
Old Dec 31, 2003 | 08:37 PM
scorp508's Avatar
scorp508
Default Re: Removed Air Pump............ Questions (AGENT 86)
The two solenoids next to the AC compressor and anything connected to them.
Old Dec 31, 2003 | 08:57 PM
AGENT 86's Avatar
AGENT 86
Default Re: Removed Air Pump............ Questions (scorp508)
Thanks, Got those but not sure where all the plumbing goes :D
:cheers:
Old Dec 31, 2003 | 09:42 PM
scorp508's Avatar
scorp508
If you've got the stock manifolds there is a tube that connects to the "AIR Trees" on the top of each one. It comes along the front of the block and meets up to a rubber hose in the center by those valves. Then there is the line that feeds the catalytic convertor. Then there is the "silencer" that hangs down off of the bottom of the AC compressor bracket.
Old Dec 31, 2003 | 09:49 PM
AGENT 86's Avatar
AGENT 86
Thanks, I'm assuming that the one that dissapears from under the solenoids is going to cat.
Did you have to pull compresor to remove crossover tube ?
Not sure if I will pull exhaust and weld the holes shut at this time.
Should I just plug the hoses at the check valves ?
:cheers:
Old Dec 31, 2003 | 09:52 PM
scorp508's Avatar
scorp508
The crossover is a pain. You can't get it out without unbolting the AC compressor bracket. Not that that is hard, just something else to do. :)
Old Dec 31, 2003 | 10:05 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
You can take the check valves OFF and go buy 2 , 1/2 inch threaded pipe caps in the plumbing section and cap the exhaust a.i.r tube off on both sides.Its round so use a good vise grip wrench to tighten them on.
I did this until I cut the air tubes off the manifolds and got the holes welded shut.The long pipe that goes to the cat,I took that off and I used a fat screw to put inside the rubber connector at the main cat and a clamp to seal it and it never leaked.
:cheers:
Old Jan 1, 2004 | 01:59 AM
AGENT 86's Avatar
AGENT 86
Default Re: Removed Air Pump............ Questions (Bill's86Coupe)
Thanks everyone !!
Hope your having or had a great new years :cheers:
To Removed Air Pump............ Questions
