ECM programming for 90 - L98
Old Jan 2, 2004 | 11:35 AM
Raheel's Avatar
Raheel
Default ECM programming for 90 - L98
Is there a programmer one can buy to program the PROM in 1990 L-98? Or do you need to get it burned by one of the pro shops? Is so, does anyone have any recommendation? Cost?
Thanks in advance
Raheel
Old Jan 2, 2004 | 12:25 PM
AKS Racing's Avatar
AKS Racing
Default Re: ECM programming for 90 - L98 (Raheel)
Back when I used to do the factory ECMs, the best pro shop that I found was Formato Faster Proms (Eileen & Jeremy Formato). They continue the legacy of the late Jim Formato.
Aaron
Old Jan 2, 2004 | 02:47 PM
tjwong's Avatar
tjwong
Check this thread out if you want to do it yourself. There is a link to the thirdgen.org website where there is lots of information on how to burn your own proms and where to get all the hardware to do it.
http://forums.corvetteforum.com/zerothread?id=716318
If you don't want to then check out Formatto, they used to do LPEs chip tuning when Jim Formatto was around. Jeremy his son has taken over the operation and is doing well with it.
Old Jan 2, 2004 | 03:34 PM
Raheel's Avatar
Raheel
Default Re: ECM programming for 90 - L98 (tjwong)
Thanks a lot guys. You rule!!! That's exactly the information I was looking for. :cheers:
Old Jan 2, 2004 | 04:49 PM
Baldturbofreak's Avatar
Baldturbofreak
Tunercat has the software neccisary for the job. If you use a rom-emulator they have software to tune it Real time with your laptop. Then you just buy a $100 prom burner for the final calibration. Go to TUNERCAT.COM
Old Jan 2, 2004 | 05:07 PM
Dcvertigo's Avatar
Dcvertigo
Thats a lot of really good information! :thumbs:
To ECM programming for 90 - L98
