New engine won't start.... Help!
Old Jan 3, 2004 | 12:40 AM
timallard's Avatar
timallard
Default New engine won't start.... Help!
Just got the the new engine put back together. Tried to fire it up and it won't run. It fires but won't catch. I have double checked everything that I can think of. Fuel pressure and oil pressure is good.
Any suggestions? I'll try anything at this stage.
Cheers
Old Jan 3, 2004 | 12:46 AM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: New engine won't start.... Help! (timallard)
Its usually the cam when we hear this.....
I would double check the usual, but be sure to check the sensors on the front of the intake manifold under the TB, if its off, the engine will not start. Also the ECM leads and fuses, the injector harness, check the timing, and make sure your esc wire is connected, check firing order. The connectors on the distributor cap are a pain to get on, sometimes they dont get on right.
I hope its something silly like that, and not your cam....
keep us posted. Maybe you should get some rest and get a fresh perspective in the morning when your not so tired, frustrated, and there is more light!
kman0066's Avatar
kman0066
Check **timing**, check for vacuum leaks, there's a couple of ideas.
Did you just through in a rebuilt motor or is this a custom engine.
Old Jan 3, 2004 | 12:51 AM
timallard's Avatar
timallard
Default Re: New engine won't start.... Help! (kman0066)
Custom engine.
1989 auto, 355ci , superram, 219 cam, new ported heads, long tube headers. I am waiting on a custom chip but it should still run (shouldn't it?).
Also I am not tired. I'm in Australia so it is the middle of the day here. If I don't get it started soon I will start to get tired though.
Old Jan 3, 2004 | 12:59 AM
kman0066's Avatar
kman0066
Yeah, it should run without the custom chip as long as you haven't done something like switch from high impedance injectors to low impedance.
Old Jan 3, 2004 | 01:22 AM
weekendwrench's Avatar
weekendwrench
Start with checking the timing and the order of your spark plug wires. I have seen the wires run in the wrong direction. The firing order is 18436572 make sure the direction you connect the wires is the same direction the rotor turns.
To set the timing without having the engine running do the following. Crank the engine over until the timing mark is at 8 degrees BTDC with the number one cylinder on the compression stroke. Then make sure the rotor is pointing at the number one sparkplug wire. Replace the dist cap, turn the ignition to "on" and move the distributor back and forth until a spark is fired out the number one wire. You will need to have the spark plug wire disconnected from the plug, put a screwdriver or something in the end of wire so that you can see a spark jump to ground. When the spark is fired the timing is set at 8 degrees, tighten the dist. and try to start the car. Do you know if you have spark?
Good Luck
Old Jan 3, 2004 | 01:29 AM
scorp508's Avatar
scorp508
Default Re: New engine won't start.... Help! (weekendwrench)
Make sure you aren't 180* off on the distributor. :cheers: And yes the 219 will run no problem with the stock chip. In fact it'll run damn good.
Old Jan 3, 2004 | 05:13 AM
timallard's Avatar
timallard
Default Re: New engine won't start.... Help! (scorp508)
Got it running now. Please se my other post
http://forums.corvetteforum.com/zerothread?id=722268
To New engine won't start.... Help!
