Harmonic Balancer install question.
I was putting a new stock 87 harmonic balancer on my internally balanced 406 with a Callies crank. I used a HB installer to pull the balancer on until it stopped, then proceeded to put the stud in and the crank pulley on. At this time I noticed that the balancer was about 1/8 (.125) back too far to line up with all the other pulleys on the motor. So first thing I figure is I have to make a spacer. As I am getting the materials together to do it I realize I have no idea just how far in the balancer is supposed to go in. I pull it off again and measured the distance from the end of the crank snout to the face of the lower timing gear, then measured the depth of the harmonic balancer itself. The difference was exactly 1 inch. When installed on the engine now the difference is about .9 or said a different way the snout face of the crank is a little less than an inch down from the front face of the balancer. I thought to myself, uh, oh, maybe I pushed the timing gear on a bit too far and put things out of alignment, that wouldn't be good. So then I started looking for some type of measurement as to how far in to install the balancer. Maybe a figure for how far down the crank snout should be or how far the balancer face should be from some reference point on the block. I haven't found any mention anywhere as yet. Because the block, crank and balancer are all from different years could it just be tolerances being off. I would much rather just pull the balancer out .125 than fabricate a spacer with the machine work required to have it done right. I can get the crank stud to the spec torque value with the crank out another .125 but if its supposed to be crushed up against the timing gear that would be bad. Thanks for any help or information you all can throw my way. Happy Holidays.
P.S. after spend a small fortune on this motor I wasn't that thrilled with using the stock harmonic balancer (new though), and was thinking of either the 6.25 Fluidampner or the 6.28 ATI rattler. Don't know which is better if anyone has a recommendation..thanks again.
http://www2.freepichosting.com/Images/84456/1.jpg
[Modified by Jaxian, 4:52 PM 1/3/2004]
The crank gear is pressed on to a certain depth to align with the cam gear and the timing chain. The collar of the balancer is designed to snug up to the crank gear, which prevents any possibility of the gear walking forward as thrust is applied. It's then torqued in place.........the seal is on the timing cover around the balancer collar, no matter what the depth of the balancer is. The variable is in the design of the pulley (alignment in and out) depending on the accessories. If your pulley is too far rearward, you could use spacers under it against the balancer in the form of flat washers, etc.
If you used all stock components and have a problem, I'd want to know why before I called it a day and simply spaced things to alignment. Could it be the crank gear isn't fully pressed on and the chain is a little out of whack? If the timing gears line up, then I wouldn't worry too much about it.......heck, how did you find that 1/8" anyhow? :lol:
As to how I noticed the .125. I had boltedt the crank pulley on and was looking at it from the side when I noticed it seeming to be off a bit. I layed a straight edge across the crank pulley and measured the difference in relation to the waterpump and other pulleys. Its noticeable because 1/8 (.125) is almost exactly one rib on a 6 rib factory belt setup. You can see the belt kind of deflecting over the little bit its off. Its not too critical on the water pump because that is driven by the back of the belt and has some extra slop space, I was more worried about the supercharger and alternator and A/C not being aligned correctly. Hopefully the timing gear is correctly aligned when it is up against the stop on the crankshaft, that would seem to make sense. I will try to get the pictures up again and hopefully the hosting site is working now. Thanks again.
[Modified by Widebody, 7:00 PM 1/3/2004]
I tried to IM you, but it's disabled
