4 Bolt Main Caps
Y-bodies came with 4 bolt mains, and F-bodies came with 2 bolt.
When Building an engine it is more desireable to get an F-body block so you can put 4 bolt splayed mains on?
Can you put 4 bolt splayed mains on a Y-body engine?
Also most crate engines seem to come with some type of upgraded main caps they seem to only do the three middle ones.
Why? I know it is harder and costlier to do the two end ones but what are the gains or losses of doing them or not?
It would seem that if you are building a hardcore engine it would be good insurance?
Huum! back in the 60's I was always building 2 bolt mains-had them built to turn 10k RPM, never had a problem, I forget what year they switched to 4 bolt mains (by the way I'm referring to small blocks only). Later the general went to 4 bolt-I'm not sure what yr. without looking it up, but hey-4 bolts were definitely stronger :rolleyes: but you know-I never have launched a crank :hurray:
Some of the newest Vette engines have 4 bolt caps, but not the earlier ones.
Yes, 4 bolt caps can be added; I'm using Oliver's on the center 3 and studs on all five.
The general consensus is that two bolt blocks are the most desirable, over 4 bolt blocks. A two bolt block is stronger (better casting) and after adding 4 bolt caps to the center three, it is much better than a four bolt block.
I suspect that the center three are the only ones that get the four bolt caps is due to chassis/oil pan clearance problems.
Jake
its overkill for most motors. Its a lot like the wonderful idea that everyone needs forged internals on their 450hp rebuild :rolleyes:
I think Rick's answer begs the question, "what kind of power are we looking at here?"
I would like 500 HP and maybe 7000 to 7500 RPM, but I know it all depends on components.
I was interested in the strength of the bottom end and its relationship to the main caps.
I have heard that a stock LT1 will not sustain more than 6300RPM.
Thanks for all the replies
The limiting factor on a 350 over 6300rpm is the valve train, not the bottom end. I've seen 327s and 350 spun up to 7500rpms regularly with 2 bolt mains and good head / valve train combinations.
396s are different animals. The stroke of the 396 puts added stress on the crank, bearings, and connecting rods. Short duration blasts up to 5800 - 6000rpms (1/4 mile) and two bolt mains are probably okay. 20 - 30 minute stretches with the rpms running up to 6200 - 6800rpms (road course) require 4 bolt caps or you will see problems.
