ZF-6 Fluid Recomend
Old Jan 11, 2004 | 11:17 PM
CaliforniaVette's Avatar
CaliforniaVette
Default ZF-6 Fluid Recomend
recomendations on Fluid for my ZF6 on my LT4... 78,500 miles on it.. and the rear end as well.. im thinkin i might as well change them
Old Jan 11, 2004 | 11:48 PM
ffvetteman's Avatar
ffvetteman
Default Re: ZF-6 Fluid Recomend (CaliforniaVette)
I used Gm syncromesh manual trans fluid
It worked GGGGRRRRREAT
Almost forgot to add I have a Richmond 6 speed
[Modified by ffvetteman, 4:49 AM 1/12/2004]
Old Jan 12, 2004 | 12:33 AM
CaliforniaVette
Default Re: ZF-6 Fluid Recomend (ffvetteman)
Richmond 6spd is the T56 correct? used on the F-bodies?
Old Jan 12, 2004 | 01:09 AM
froggy47's Avatar
froggy47
http://www.zfdoc.com/index.htm
Old Jan 12, 2004 | 01:42 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
You're making recomendations on fluids, even though you don't have a ZF6??? :confused:
Either use the factory ZF6 fluid from GM, or use the Castrol which you can buy from the BMW dealership.
Old Jan 12, 2004 | 01:43 AM
JasonL's Avatar
JasonL
The T56 is Borg Warner and later, Tremec.
Old Jan 12, 2004 | 02:57 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
When I change my 96's, I am going to use what is specified in the owners manual. I have always used the GM lubricant in the rear end of my 70 since it was new and it has 160K on it now with no known problems using GM lubricant. I always change my own.
Old Jan 12, 2004 | 09:54 AM
GS919's Avatar
GS919
I used the BMW synthetic oil recommended by ZF for the tranny. It shifts smoother than the GM stuff IMHO. :thumbs:
Old Jan 12, 2004 | 10:08 AM
85z51vette's Avatar
85z51vette
Default Re: ZF-6 Fluid Recomend (GS919)
:iagree:
Old Jan 12, 2004 | 11:17 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
:iagree:
The GM stuff felt a little "notchy" but the BMW stuff makes it smooth as silk.
Old Jan 12, 2004 | 07:52 PM
CaliforniaVette
Default Re: (Professor)
so is the BMW oil only at the dealer?
Old Jan 12, 2004 | 08:02 PM
FU's Avatar
FU
Race Director<br><img src="/forums/images/ranks/7k-10k.gif" border="0">
From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Default Re: ZF-6 Fluid Recomend (froggy47)
<A HREF="http://www.zfdoc.com/index.htm" TARGET="_blank"> http://www.zfdoc.com/index.htm</A>
Call Bill at the above site. He will send the BMW fluid to you.
Good stuff !
Old Jan 12, 2004 | 08:33 PM
no_radio's Avatar
no_radio
Default Re: ZF-6 Fluid Recomend (FrankUrbinati)
You can get the BMW fluid at any BMW dealer, tell them you are a club member and it's about 50% off.
It made my 90K mile ZF6 shift much, much better, and the effect has lasted 2-3 months so far.
Jeff
Old Jan 12, 2004 | 09:06 PM
CaliforniaVette
Default Re: ZF-6 Fluid Recomend (no_radio)
Jeff
50% off!!! what? a club member... of this forum or of an actual vette club.
Old Jan 12, 2004 | 09:25 PM
Strick's Avatar
Strick
:iagree:
Let's compare apples to apples. If you have the GM stuff and it's old, when you remove it and refill with Castrol (BMW stuff) of course it's going to feel better. So will the GM stuff when it's new. Both will work just fine.
Old Jan 12, 2004 | 11:10 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Default Re: (Strick)
:iagree:
Actually, I was comparing apples to apples. Sorry I did not explain.
When I first got my 90 it had a little grinding in 3 and 4 so I replaced the fluid with GM stuff. I do not think the previous owner ever changed it in 125K so there was an improvement but it was not much. I was underwhelmed.
After 10k miles I switched to the BMW stuff and it showed an immense improvement. The only downside it that the tranny is a little more stiff in the mornings (Garage is 20*F most of the time).
Sorry for the confusion.
Dale
Old Jan 12, 2004 | 11:19 PM
SPEED750's Avatar
SPEED750
Stick with the BMW juice. I filled mine with REDLINE MTL "blue martian blood" and it about killed my ZF.It would not go into 3rd or 4th half the time.I switch it out and ran BMW/CASTROL now it's back to normal.IMHO the redline has to many additives.You can't even see though it when you pour.It might be great in some trannys, but I think the ZF has alot tighter tolerances.Learn by my mistakes!! :cool:
To ZF-6 Fluid Recomend
Old Jan 13, 2004 | 12:07 AM
CaliforniaVette
Default Re: (SPEED750)
Thanks everyone, I emailed Bill at ZFdoc and he got back to me right away with some great tips!
Old Jan 13, 2004 | 10:20 AM
Strick's Avatar
Strick
Default Re: (CaliforniaVette)
So what were the tips? No secrets here. :thumbs:
Old Jan 13, 2004 | 10:38 AM
wake's Avatar
wake
Interesting tidbit I got off that site...
The ZF S6-40 6-speed transmission is lubricated by engine type oil. Manufacturer recommendations specify the use of GM P/N 1052931 (5w-30) or BMW P/N 07510009420 (10w-60) oil.
Approximate oil capacity of the ZF S6-40 is 2.2 quarts.
So the GM stuff is 5W-30 and the BMW stiff is 10W-60??? That seems like quite a spread to me on viscousity levels for the same trans... :confused:
Looks like I'll be going by the BMW dealer though and picking up the "good stuff"... :lol: That'll be one of the first projects when I get the LT4 home this week... :yesnod:
