Removing 02 sensor.... Help!
Old Jan 12, 2004 | 03:43 PM
85vetteguy's Avatar
85vetteguy
Default Removing 02 sensor.... Help!
Replacing 02 sensors in my 96 Pont. Sunfire 2.4L. The one in the manifold was a piece of cake. The one after the cat is giving me a fit. :banghead: I have soaked it down in liquid wrench and have the special socket but it won't budge. What are my alternatives? Any suggestions? I know this is not a C4 but thought I would get more response here. I also posted in other cars. I apoligize if this is breaking the rules. If so then a mod can delete it. Thanks in advance, Guy
Old Jan 12, 2004 | 03:49 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Removing 02 sensor.... Help! (85vetteguy)
you could try heating it up, just be carful....
Old Jan 12, 2004 | 03:57 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Removing 02 sensor.... Help! (vinnies87)
Can you get leverage on the wrench in any way? I attach a 3ft Pipe on the ratchet wrench when things wont break loose.... Probably wont help ya but what the hell huh?
:leaving:
Old Jan 12, 2004 | 04:30 PM
tjwong's Avatar
tjwong
Heat up the exhaust pipe where its screwed in with a blue tipped wrench until its red hot. Then with your special socket try to remove it. It may be just corroded in place. You may have to use a thread chaser on the threads afterwards. Just get a 18mm spark plug thread chaser and clean out the threads with that. Its cheaper than a standard 18mm tap.
Old Jan 12, 2004 | 05:16 PM
ZylaRace's Avatar
ZylaRace
Default Re: Removing 02 sensor.... Help! (tjwong)
When the nut side glows orange, it will come out w/o a problem. You want the whole nut-side glowing. Juss don't melt the metal, or you will left w/ a hole to fill.
Old Jan 12, 2004 | 09:51 PM
SunCr's Avatar
SunCr
Before you take the torch to it, just warm up the motor and then try to remove right after you shut it down. Works everytime for me.
Old Jan 13, 2004 | 04:20 AM
86PACER's Avatar
86PACER
Default Re: Removing 02 sensor.... Help! (SunCr)
:iagree: with SunCr
To Removing 02 sensor.... Help!
