Tuning education.
Old Jan 16, 2004 | 06:49 PM
CNTDRV55's Avatar
CNTDRV55
Default Tuning education.
I know it is too much to expect a book on OBDII specific PCM file editing, but what are your recommendations for learning to tune a car, e.g. the parms that can be edited and what function they perform.
How does one learn this stuff? Trial and error?
[Modified by tailgunner, 5:51 PM 1/16/2004]
Old Jan 16, 2004 | 11:23 PM
96GS#007's Avatar
96GS#007
Default Re: Tuning education. (tailgunner)
Bascially read everything you can get your hands on. Search the web. Join the main LT1 Edit mailing list and also search the archives. The LT1 Edit website has a "tutorial" that tells what the software changes. Although it's for the OBD I version, the OBD II version is very close. Focus on understanding idle and part throttle fuel trims and then progress into timing and WOT. The more mods you make to your car, the more complicated the tuning can become.
Old Jan 17, 2004 | 01:01 AM
Dan Parker '96's Avatar
Dan Parker '96
Remember this mantra, "It's incredibly difficult to outsmart a gaggle of engineers". GM paid a crap-load to a large team of engineers to make sure their engine would perform the way they claimed.
This statement may look stupid but what it means is to take tuning modifications in "small digestible bites".
Only do what is necessary to make your engine run well. You can't outsmart the original designers. They've done a good job.
You can only match the PCM to the mods you've done. Since the PCM is well adjusted, you'll have to make pretty major engine changes to confuse it. Anything less than a cam change means that there is no use in modifying the PCM.
As far as learning goes, read "How to Understand, Service, and Modify Corvette Fuel Injection & Electronic Engine Management" by Charles O. Probst. It's a solid primer. The rest you can search on this forum.
Good luck :)
[Modified by Dan Parker '96, 12:06 AM 1/17/2004]
Old Jan 17, 2004 | 11:37 AM
CNTDRV55's Avatar
CNTDRV55
For anyone else interested......I found this website that links to the forums that 96GS007 referred to, and has good info for the beginner. http://lt1edit.schube.com/
I recently added the hotcam so I am interested in code 'scannage'
and fuel trim.
Thanks. :cheers:
Old Jan 17, 2004 | 10:08 PM
tjwong's Avatar
tjwong
Also check out the thirdgen.org website under the DIY Prom forums. There is a bunch of knowledge there and information on the older ECM stuff with removable proms. Also check out the DIY EFI website theres lots to learn there as well.
http://www.thirdgen.org/techbb2/foru...?s=&forumid=16
http://www.diy-efi.org/gmecm/
Yes, lots of its is older prom style ECMs vs the newer flash programmed PCMs but the basic operations and theory is all the same between the early and late model controllers.
To Tuning education.
