Started the car this morning and it runs rough. It is pulling a code 32. What is a code 32? Any suggestions on what or where I need to look. :confused:
I cleared code 32 by installing a new EGR Switch. Disconnected the battery for 10 minutes and code never returned. Cost was $13 at a local GM Dealer.
Check this site out for solving any future codes. Just scroll to the bottom for a table with all the codes, and their most common causes. :thumbs: http://www.c4vettes.com/ecm.htm
EGR temp switch probably is stuck closed, does the light go off when the car warms up?
This happened to me and was the EGR temp switch...Code 32 can be tricky sometimes.
You might want to throw a meter across it just to be sure you're not replacing the wrong part when you take it apart...happened to me.. Good luck
