Quick answer needed on an 1990 L98
Old Jan 20, 2004 | 01:36 PM
Huckzilla's Avatar
Huckzilla
Default Quick answer needed on an 1990 L98
I'm in the process of selling my 1990 Coupe. The initial horsepower rating from factory was 245hp. However, there were some (mine included) that had a higher rating of 250hp. Does anyone know why? The buyer is questioning this and I can't remember the reason. Something tells me the exhaust was different in mine that created the additional 5hp.
Old Jan 20, 2004 | 01:40 PM
scorp508's Avatar
scorp508
Default Re: Quick answer needed on an 1990 L98 (fast90)
90 and 91 got flat-top pistons which bumped the compression ratio a little and also the HP.
Old Jan 20, 2004 | 01:47 PM
Huckzilla's Avatar
Huckzilla
Default Re: Quick answer needed on an 1990 L98 (scorp508)
:seeya Scorp! I knew I could count on you to post an answer.
So, it really had nothing to do with the exhaust?
Old Jan 20, 2004 | 01:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Coups with performance axle ratio had 250chp due to less restrictive exhaust; others had 245chp.
Look for RPO G92 on the RPO list under the console lid.
Old Jan 20, 2004 | 02:01 PM
Tom73's Avatar
Tom73
Default Re: Quick answer needed on an 1990 L98 (65Z01)
:iagree:
The 250hp cars had less restrictive exhaust which was only available with the performance axle.
tom...
Old Jan 20, 2004 | 03:41 PM
vader86's Avatar
vader86
minor exhaust differences
Old Jan 20, 2004 | 04:49 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Quick answer needed on an 1990 L98 (vader86)
I got a vert with the performance axel. How do i know if if got the extra 5? I always assumed it had 245 just cause its a vert. It had the exhaust with the one false outlet mufflers and 2" rear y. Even though i modified the car slightly for more power, im still curious.
Old Jan 20, 2004 | 05:07 PM
Tom73's Avatar
Tom73
Default Re: Quick answer needed on an 1990 L98 (blk90rdstr)
Only the coupes. Guess they considered it too loud for the Verts :(
Old Jan 20, 2004 | 07:19 PM
1990CORVETTE's Avatar
1990CORVETTE
He is wrong,, it is because of less restrictive exhaust.......... :cheers:
Old Jan 21, 2004 | 05:31 PM
corvette1990's Avatar
corvette1990
Default Re: Quick answer needed on an 1990 L98 (1990CORVETTE)
I ordered my 1990 from the factory and saw it built, so I speak from experience of an original owner/buyer. The answer is as many have said, a less restrictive exhaust came with the performance axle (3.07). It says on the window sticker 250HP. The mufflers did indeed have one fake pipe and one working on each of the dual mufflers. I noticed improved seat-of pants feel, when I took those less restrictive mufflers off and replaced with targa mufflers (but loud). I eventually changed to Borla mufflers that changed the sound to another different level. However if you dyno the car, you will discover that the HP figure is really a flywheel number, so I have no Idea why the muffler change is worth 5 more HP over a flywheel
Old Jan 21, 2004 | 09:29 PM
coopsl98's Avatar
coopsl98
Default Re: Quick answer needed on an 1990 L98 (corvette1990)
"It says on the window sticker 250HP"
Funny the window sticker for my 1990 (w/G92 3.07 ratio) does NOT list HP, nor does any other years window sticker for that matter.
Old Jan 21, 2004 | 09:33 PM
scorp508's Avatar
scorp508
He is wrong,,
I wouldn't be so quick to say that.
Old Jan 21, 2004 | 09:40 PM
coopsl98's Avatar
coopsl98
"I wouldn't be so quick to say that"
I would!
Speed density system, new cam, AND an increase in comp. ratio added 5HP to the BASE rating of 240, making it 245. 250 HP was due to a less restrictive exhaust, which was only available in the coupe w/ 3.07 or 3.33 gear ratio.
To Quick answer needed on an 1990 L98
