brake calipers
Old Jan 21, 2004 | 06:23 PM
kohlbear's Avatar
kohlbear
Default brake calipers
Can they be checked for sticking by applying the brakes and observing their movement with the wheels off?
Old Jan 21, 2004 | 06:36 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: brake calipers (kohlbear)
I'm not sure if having the wheels off would help but spinning both wheels and observing how they stop when brakes are applied lightly might turn up some caliper sticking.
Old Jan 21, 2004 | 06:59 PM
bogus's Avatar
bogus
the only thing that trick will do is push the pistons out of the calipers...
Old Jan 21, 2004 | 07:30 PM
ittlfly's Avatar
ittlfly
Default Re: brake calipers (bogus)
the only thing that trick will do is push the pistons out of the calipers... [/QUOTE]
:confused: Correct me if I'm wrong, but he only wanted to remove the wheels, not the rotors. So how could the pistons pop out of the calipers if they are still in place? Maybe I'm getting dense. :D
[Modified by ittlfly, 4:32 PM 1/21/2004]
Old Jan 21, 2004 | 08:26 PM
65Z01's Avatar
65Z01
Default Re: brake calipers (ittlfly)
Or perhaps I wasn't clear enough above.
What I had in mind was to jack the front axle, spin the two front wheels (with wheels on the axles) and watch how the wheels come to a stop as someone lightly applies the brakes.
If one wheel repeatedly seems to stop sooner, spin that one a little harder; if it still stops sooner then that caliper is is hanging up, possibly due to sticking pistons.
Old Jan 21, 2004 | 08:50 PM
kohlbear's Avatar
kohlbear
Default Re: brake calipers (65Z01)
Very good idea! That seems logical. Anyone else have ideas? :hurray:
Old Jan 21, 2004 | 08:58 PM
kohlbear's Avatar
kohlbear
Can I get by with only replacing the one bad caliper?
Old Jan 21, 2004 | 09:10 PM
ittlfly's Avatar
ittlfly
Sure. But it is a good idea to freshen up both sides of the axle at the same time for effective braking.
kohlbear's Avatar
kohlbear
Any way to tell if its the calipers or brake lines? :chevy
To brake calipers
