tps voltage
Old Jan 23, 2004 | 09:00 AM
89blkvet's Avatar
89blkvet
Default tps voltage
I am having a hrad time measuring my TPS voltage with the "Paper Clip" method. Is there another way that I can measure this to get an accurate reading.....Thank you
Old Jan 23, 2004 | 09:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: tps voltage (89blkvet)
There is a patch cord that you plug in between the connectors to simplify measurement.
I sharpened two paper clips and I slide them along the top of the wire into the connector. I get them far enough in to make connection with the pin in the connector. Works everytime.
You are using the top to wires of the TPS, Right ?
My laptop and software now take over for the paper clips :D
:cheers:
Old Jan 23, 2004 | 11:32 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Got one from MAD before my computer was setup... works fine, think the test plug kit was $19.00... :thumbs:
Old Jan 23, 2004 | 01:54 PM
JAKE's Avatar
JAKE
Default Re: tps voltage (AGENT 86)
:cheers:
I was wondering if you ever made a back to back test to see if there is any difference in voltage when checking the TPS with the engine "off"/ignition "on" Vs engine idling?
If there is none, it would be a lot easier for me to check/set mine using Diacom with the engine idling, rather than using jumper wires on the TPS itself.
Thanks,
Jake
Old Jan 23, 2004 | 02:54 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: tps voltage (JAKE)
The TPS is adjusted with the throttle at base idle (~450RPM) positiion, while normal idle is around 600-700RPM.
With the IAC disconnected, ignition on and engine off you may be able to read the TPS voltages, though I can't recall if the scanner will get sensor values with the engine not running.
Old Jan 23, 2004 | 03:53 PM
89blkvet's Avatar
89blkvet
Default Re: tps voltage (65Z01)
So the IAC needs to be disconnected before I can check the voltage on the TPS ????
Old Jan 23, 2004 | 08:20 PM
65Z01's Avatar
65Z01
Yes, to set the TPS low voltage the throttle position needs to be at base idle.
The method to establish base idle and adjust the TPS is on my site.
Old Jan 23, 2004 | 08:52 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
:iagree:
Old Jan 24, 2004 | 12:40 AM
AGENT 86's Avatar
AGENT 86
:cheers:
Thanks,
Jake
I can't see why there would be a difference. The tps doesn't know if the car is idleing or sleeping :smash: It's like my light dimmer switch. I slide it to a low glow and turn the power off. When I turn the power back on the light level is the same. :jester
Old Jan 24, 2004 | 12:49 AM
JAKE's Avatar
JAKE
Well, if that's the case, then the engine cannot be running when the TPS voltage is checked.
My engine won't idle at 450 RPMs and Diacom won't show anything with the engine NOT running.
Are you sure about that IAC having to be disconnected part?
No matter whether the engine is idling or off, the throttle position doesn't change. The only change occurs when the engine is idling and the IAC maintains the idle speed; still the throttle remains stationary, only the IAC pintel moves.
Jake
[Modified by JAKE, 11:51 PM 1/23/2004]
[Modified by JAKE, 5:56 PM 1/24/2004]
Old Jan 25, 2004 | 12:33 PM
SunCr's Avatar
SunCr
Jake's right - there's no mechanical linkage between the IAC and the TPS so it doesn't matter whether it's adjusted with the IAC disabled or enabled. You will need to adjust it if you change the angle of the throttle blades, but there's little reason to do make that adjustment unless the throttle body is worn or dirty (at which point you need to clean it first). If you want to make an inexpensive test rig, obtain some female weatherpak terminals and some 10 to 12 gauge solid strand copper wire. Cut the wire into 1 to 2 inch lengths and solder or crimp it to the weatherpak connectors. Insert the connectors into the male half of the TPS harness and the wire ends into the female half, making sure that none of the connectors touch one another (or if you want to minimize that risk, cover the majority of the connectors with shrink wrap). Hookup a DVM to the connectors from the appropriate leads (return voltage is blue and ground is black). Turn on the ignition and adjust TPS voltage to .54 +/- .08.
To tps voltage
