Intake Question
Old Jan 27, 2004 | 10:00 PM
1990CORVETTE's Avatar
1990CORVETTE
Default Intake Question
Can I and is it possible to put a LT-1 intake on my 90 L-98,,, I am sure this questionahas been brought up a million and two time ,, but gotta know the answer,,,, Isnt it the same concept as the miniram?
If it is possible what would I need? :eek: :confused:
Old Jan 27, 2004 | 10:06 PM
steveb's Avatar
steveb
Default Re: Intake Question (1990CORVETTE)
www.lt1intake.com
Old Jan 27, 2004 | 10:36 PM
vader86's Avatar
vader86
Default Re: Intake Question (steveb)
:withstupid: or the Miniram, same concept
Old Jan 27, 2004 | 10:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The LT1 heads flow coolant differently than do the L98s so the intake may not be compatable.
I believe the intake runers on the mini ram are longer than on the LT1.
Old Jan 28, 2004 | 06:09 AM
vetteoz's Avatar
vetteoz
Default Re: Intake Question (65Z01)
As per the above site , with the mods for the dist and provision of the water outlet to a remote thermo housing it fits.The theory says with the right complimentary parts ,heads ,cam etc it should make HP .I think we are all waiting to for someone to run some documented back to back test to prove the point. On a stock L98 it is probably going to be too much.
Other post seem to have concentrated on poor quailty workmanship resulting in bad fit / leaks rather than the performance aspect.
The bottom lines is it fits under a Vette hood and is relatively cheap in relation to the other options , especially if you can do the mods yourself.We all just want to know if it is worth the effort.
Is on my future to do list as the alternatives are too expensive down here.
Old Jan 28, 2004 | 12:58 PM
Z-PDX's Avatar
Z-PDX
Default Re: Intake Question (vetteoz)
go do a search on http://www.thirdgen.org
Search the TPI section under "LT1 intake"
Tons of info. Most feedback VERY positive.
-Z
To Intake Question
