HEI Tach output
Old Jan 30, 2004 | 05:57 PM
ZD1's Avatar
ZD1
Default HEI Tach output
I'm trying to hook up a AFR meter that will take in pulsed outputs. Where can I get a pulsed output on a 91 w/ HEI distributor and how many pulses per rotation?
Old Feb 1, 2004 | 12:01 AM
ZD1's Avatar
ZD1
Default Re: HEI Tach output (ZD1)
Can any one help, just need to find out which wire has a pulsed output.
:cry
Old Feb 1, 2004 | 12:06 AM
tjwong's Avatar
tjwong
You should be able to use the negative wire from the ignition coil. That is a pulse output. It should be pulse 8x with every cam revolution or 4x with every crank revolution. What AFR meter do you have? If you have a TECHEDGE be sure that the internal jumper is set for a tach input from the coil otherwise you could fry its electronics. The TECHEDGE units can take either a low voltage pulse from a pick up coil which is a 2.5 to 3.5v PP pulse, or it can take a 12v signal from the module coil driver circuit, its determined by a jumper inside its case on the circuit board.
Old Feb 1, 2004 | 03:32 PM
ZD1's Avatar
ZD1
Default Re: HEI Tach output (tjwong)
I'm using the an innovate unit although I love the Aussie's I by american when I can. (Although It is probable made in china!). The Techedge unit copied (stole) their information from WB-O2 website here in the US.
To HEI Tach output
