Injector - which one to use?
Feb 1, 2004 | 11:12 PM
The motor going into my vette this spring will be:
350, ZZ-4 roller cam, and 882 heads ported to flow roughly 225-230cfm with 1.94/1.5 valves.. ported plenum and maybe siamese the base
not a crazy motor by any stretch but im expecting mid-low 13's on it
my question is which injectors do i use?
right now my immediate choices are the ones in there now which are stock 22 lb/hr injectors and my other choice is a set of lt-4 28 lb/hr injectors.
can i get away with the 22's with an AFPR or should i just go with the 28's while i have it all apart?
Feb 2, 2004 | 12:09 AM
Re: Injector - which one to use? (CarAteMyMoney)
Feb 2, 2004 | 12:19 AM
Re: Injector - which one to use? (SPEED750)
24's are good to 450 hp.
Feb 2, 2004 | 05:01 PM
Re: Injector - which one to use? (BAM92)
so 22's should be good for my application with a nice afpr?
Feb 2, 2004 | 06:22 PM
:yesnod: I think the 28's are too big.
Feb 3, 2004 | 10:05 AM
Re: Injector - which one to use? (1MoorTym)
28 too big, but 24's will do you proud!! :seeya
