Does a by-pass help?????
Old Feb 10, 2004 | 09:08 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Default Re: Does a by-pass help????? (midlifecrisis91)
I removed mine and machined the extra metal away so now i just have the iac and the three screws around it.Lokks much cleaner and removed alot of clutter around throttle body.
Old Feb 10, 2004 | 09:17 PM
jpee's Avatar
jpee
Default Re: Does a by-pass help????? (crash1mac)
All of you guys said you didn't see any improvement in performance. I ran 12.90 then I bypassed the TB & ran 12.28 :D
Just kidding ;) I do ONE mod at a time & run it several times to see if I improve, how much I gained or LOST.. Bypassing the TB showed NO IMPROVEMENT !
Old Feb 15, 2004 | 09:23 AM
pipe's Avatar
pipe
Default Re: Does a by-pass help????? (Red96Coupe)
I saw one guy at the drags who had a small round container in front of the right side wheel a little bit bigger than a cool can. He had a 12v RV pump hooked to it a switch was on his dash to turn it on and off. He filled the can with water and ice. He ran one line into the Throttle Body and one coming out when he turned the pump on it made a constant flow of cold water going through the throttle body. I felt the TB it stayed nice and cold. In all it was a pretty neat idea
Old Feb 15, 2004 | 01:50 PM
okinawa86vette's Avatar
okinawa86vette
Default Re: Does a by-pass help????? (pipe)
That's pretty cool. I wouldn't have thought of doing that. Kind of like those cold water intercoolers for the blowers.
Chris
Old Feb 15, 2004 | 03:33 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
I'll have this type system on my car soon, It can hurt.
Old Feb 15, 2004 | 08:18 PM
smacko's Avatar
smacko
Has anyone tried the same idea but with a 12v portable cooler/refridgerator stashed SOMEWHERE(???) in the car? I imgaine the setup above wouldn't do any good for more than a few minutes driving (Ice melts) hehehe :lol:
Old Feb 15, 2004 | 08:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Does a by-pass help????? (mackeyred96)
I did mine and saw a considerable decrease in the plenum temp!!! I also saw a small HP increase (seat of the pants). It's free! GO FOR IT! If you dont like it, return it back to stock!
On another HP topic, I saw a bigger HP / mileage gain in upgrading to a better ignition coil. I installed an ACCELL coil that I got from a yard sale for $3!! :thumbs: :thumbs:
Just from the coil I got a solid 2-3 MPG increase! My old origional coil could have been bad but the new one helped out significantly!!!!!!
BC
Old Feb 15, 2004 | 08:26 PM
smacko's Avatar
smacko
Default coil
BC
That's interesting!
I guess one would need to do an electrical breakdown or resistance test to see if the existing coil was tired...2-3mpg extra sounds good!
Old Feb 15, 2004 | 08:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: coil (smacko)
SMACKO
The origional GM HEI ignition is good but has it's weak points. If you up-grade to a better coil and get a better ignition module with more dwell you will find a good solid starting point for significant HP! Like I said, just the coil gave me a HP and mileage boost. No BULL!!
One thing to consider; you can spend $800. on an aftermarket distributor and coil but, if your wires and plugs are not up to par, it's all a waste of money!!
There are many aftermarket vendors that offer better ignition systems A few that I seem to favor are: Jacobs, Accel and DUI.
BC
Old Feb 15, 2004 | 08:55 PM
smacko's Avatar
smacko
Default Re: coil (Bill Curlee)
SMACKO
BC
Does the ACCEL coil fit in the same way as original coil? I hear some aftermarket ones require leaving the alloy cover (behind plenum) off...
Old Feb 15, 2004 | 09:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The cover on the Accel coil is just that, A cover! You can remove the coil from the plastic cover without hurting anything and the coil is the exact same size as the origional coil. The accell coil has smaller guage primary coil wire resulting in MORE primary wire turns! More primary turns = more secondary voltage!!
There are companys that sell high performance coils that do not come with the gimic plastic coil cover. Either way if you remove the coil from the plastic cover it will fit like the origional coil so you can retain the aluminum plemum coil cover!
BC
