throw out bearing
Old Feb 9, 2004 | 12:57 AM
Todd15's Avatar
Todd15
Default throw out bearing
the throw out bearing on my 93 vette is noisey.... should this be a concern? I got a new clutch awhile ago ......should this have been replaced with the clutch? any input would be great
Old Feb 9, 2004 | 01:00 AM
Todd15's Avatar
Todd15
Default Re: throw out bearing (Todd15)
I forgot to mention that the noise only happens when the clutch is out
Old Feb 9, 2004 | 01:03 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Yes, it is cause for concern and yes, it should've been replaced with the clutch. If it was replaced and is bad already your clutch was out of adjustment with no free travel.
Old Feb 9, 2004 | 01:08 AM
Corvette Kid
Could have some kind of an interference problem in the bellhousing then due to worn parts. Not familiar with the Vette set-up specifically. I'm sure others will have more ideas. I have seen bad bearings that got quieter when depressed but not as likely.
Old Feb 9, 2004 | 07:56 AM
trupp's Avatar
trupp
Do you have the factory dual mass flywheel? The sound you describe might be the can of rocks sound you get when you install a single mass flywheel on the ZF6. I mention this because of your statement about the noise being only when the clutch pedal is out.
Old Feb 9, 2004 | 09:21 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: throw out bearing (trupp)
My 92 does the same thing if it makes you feel any better. I also spent a lot of money to get the clutch put in..... :mad
Old Feb 9, 2004 | 01:58 PM
purplemajesty's Avatar
purplemajesty
Default Re: throw out bearing (Corvette Kid NC)
Only problem is, the stock hydrolic clutch is not adjustable. If it just started making noise and is only noisy when clutch is not engaged leads me to believe it is not the throw out bearing.
Old Feb 9, 2004 | 05:04 PM
Todd15's Avatar
Todd15
Default Re: throw out bearing (purplemajesty)
the clutch has always been noisy when its not engaged......Im thinking its the pilot bearing?
Old Feb 9, 2004 | 05:25 PM
torchred89's Avatar
torchred89
My 89 has 24000 miles on it now,the throw out bearing has been loud since it has had 15000 miles on it, as long it is just a wine when the clutch is out i wouldn't worry about it :auto:
Old Feb 9, 2004 | 05:28 PM
Todd15's Avatar
Todd15
Default Re: throw out bearing (torchred89)
so if its just a whine with the clutch out.....I shouldent worry? if thats the case Im not going to worry
Old Feb 9, 2004 | 05:33 PM
VetteBandit's Avatar
VetteBandit
I have an 85 and its been making noise for a while, Im not so sure its the throw bearing as apposed to any of the others involved. You can have a trany specialist look at it, but I would assume if you had the clutch replaced they would replace your throwout bearing, its simple and relitively cheap. If its driving fine I would get it checked out, but you may want to try synthetic trann lube.....that can help and/or quiet down a tranny. Some of the older C4s came with the "rock cruncher" trannys and they are natorious for making noise but being fin. Just my $.02 :p:
Old Feb 10, 2004 | 12:06 PM
Curveit's Avatar
Curveit
Throw-out bearing probably. They should always be replaced with a clutch change, many sets come with a new one. Replacing the pilot-bearing is a good idea with a high-mileage car. I would also check your tranny fluid level. If it is the throw-out bearing it will get louder in time, and eventually eat up the pressure plate.
P.S. the "Rock-crusher" was the old M-22 Muncie, with straight-cut gears. Hasn't bin used since the '70s
:chevy
[Modified by Curveit, 5:11 PM 2/10/2004]
To throw out bearing
