Smog Pump removal question
Old Feb 9, 2004 | 09:57 PM
KWCL98's Avatar
KWCL98
4th Gear
Default Smog Pump removal question
I just finished installing the air pump by pass kit from Dragon’s Breath on my 89. All the hoses have been removed and the headers have been capped off where the smog line attached. Here’s my question I’ve removed the black box beside the AC (not sure what to call it) and the hoses that connect to it. There are two electrical plugs that plug into the underside of the box, what do I do with them; just unplug them? :confused: I tired the search and did not come up with anything.
Old Feb 9, 2004 | 09:59 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Smog Pump removal question (KWCL98)
Zip tie them out of the way :smash:
No problem :thumbs:
Old Feb 9, 2004 | 10:06 PM
KWCL98's Avatar
KWCL98
4th Gear
Sounds good! Thanks for the quick reply
Old Feb 9, 2004 | 10:09 PM
ABNVET.I's Avatar
ABNVET.I
Yep ZIP and stuff. That’s what I did also. I also ran some tape around it so it wasn’t so noticeable when I shoved them back by the injectors.
:thumbs:
:seeya
Old Feb 9, 2004 | 11:23 PM
86Pacecar's Avatar
86Pacecar
What did you do on the manifolds? Did you cut the small pipes short and weld them closed or did you just leave the ugly piping on there? Doing this mod myself shortly and wondering what others have done.
Old Feb 9, 2004 | 11:37 PM
shotchkiss's Avatar
shotchkiss
Default Re: Smog Pump removal question (86Pacecar)
I just threaded a pipe cap onto my manifolds to block them off, it's not all that pretty, but it works, cost less than $1, and can be reversed if I'd ever need to in the future. The plugs I just taped and tucked.
Old Feb 9, 2004 | 11:42 PM
Tourney3p0's Avatar
Tourney3p0
I unplugged mine and taped it up.
That black unit that was removed is the diverter valve.
Old Feb 10, 2004 | 08:38 AM
AGENT 86's Avatar
AGENT 86
I will be cutting them damn tubes out of there and mig weld shut.
I also removed the EGR and will be welding that hole shut too.
When I'm finished removing all that crap the engine bay is going to be so much cleaner looking.
Not to mention easier removal of valve cover and other service duties :hurray:
:cheers:
Old Feb 10, 2004 | 06:48 PM
korvette4u's Avatar
korvette4u
Default Re: Smog Pump removal question (AGENT 86)
good work, agent, u will find a bit more power.
still working on my project: TB reconstruction, but delays have prevailed...my nos kit came in today.... :lolg: :lolg:
Old Feb 10, 2004 | 08:20 PM
90 Convertible's Avatar
90 Convertible
Default Re: Smog Pump removal question (korvette4u)
Just ordered my kit today. Now I know what to expect. :thumbs:
To Smog Pump removal question
