Installing new rockers.....
Old Feb 14, 2004 | 09:29 AM
1990CORVETTE's Avatar
1990CORVETTE
Default Installing new rockers.....
Is this just an unbolt and bolt on operation??????
What is the process? Do they need adjusting or anything? :confused: :cheers:
Old Feb 14, 2004 | 10:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Installing new rockers..... (1990CORVETTE)
You will have to adjust each valve after changing rockers.
Here is a good method for finding the heal of the lobe.
http://www.centuryperformance.com/valveadjustment.asp
:cheers:
[Modified by AGENT 86, 7:08 AM 2/14/2004]
Old Feb 14, 2004 | 10:56 AM
redcorvettedave's Avatar
redcorvettedave
Default Re: Installing new rockers..... (AGENT 86)
:conehead what kind fo cam do I have in my 94 LT1 motor.? :conehead
Old Feb 14, 2004 | 01:12 PM
1990CORVETTE
Wow , is there an easier way of doing it????????? :eek:
Old Feb 14, 2004 | 01:26 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Installing new rockers..... (redcorvettedave)
Hydraulic roller :cheers:
Old Feb 14, 2004 | 01:27 PM
JCAIRE2's Avatar
JCAIRE2
No, it's not that hard really, just messy and time consuming
Old Feb 14, 2004 | 06:17 PM
AGENT 86's Avatar
AGENT 86
Yes, If you go by the manual you can adjust 8 valves, turn crank 360 degrees and adjust the other 8.
The link I gave you is very accurate in obtaining the heal of the lobe.
Done properly, one should not have to readjust static or running rockers.
:cheers:
Old Feb 14, 2004 | 06:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I set zero lash by twirling the pushrod between thrum and finger as I tighten the nut till I just feel resistance. Then I tighten the nut 5/8 turn to set lifter preload.
Since it can be difficult to determine max lift I prefer this method:
-turn crank till #1 intake is just closing and adjust #1 exhaust
-turn crank till #1 exhaust is just opening and adjust #1 intake
Follow the above in turn for each cylinder.
To Installing new rockers.....
