Remove catalytic converter?
Old Feb 14, 2004 | 04:19 PM
Xssesive's Avatar
Xssesive
Default Remove catalytic converter?
My 86 has headers that flow into a single cat, should I just remove it and install a pipe in its place? Just curious to see what you guys thought. If I had dual cats I wouldn't worry about it, but with a single cat I thought it might restrict flow. We don't have to pass emissions here anymore so that isn't an issue. Thanks for your help.
Old Feb 14, 2004 | 06:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Remove catalytic converter? (Xssesive)
Your stock cat and stock front Y could be restricting exhust flow.
A 2 1/2" front Y, hi-flow cat and good cat-back would be worth adding. I don't think you need more flow that a hi-flow 3" cat provides.
Old Feb 14, 2004 | 06:09 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Toss the cat and the air pump :smash:
I don't think it's that restrictive till they start plugging up :eek:
I pulled the pump on my 86, and when I'm finished under the hood I'm going to pull the cat.
Once removed, I'll cut the flange off it and weld a length of pipe on it.
Once on the road, I'll drive it to the muffler shop and let the pro's cut and replace my precats with pipe.
Heck, If i'm feelling energetic I'll pull the Y out and do it my self :smash:
It sure would be nice to have a lift :blueangel:
:cheers:
[Modified by AGENT 86, 3:10 PM 2/14/2004]
Old Feb 14, 2004 | 06:13 PM
TA's Avatar
TA
I think you'd get a pretty nice gain, by ditching the cat and putting a pipe in its place. My 1/4 mile times improved by about .15 after hollowing the main cat. :yesnod:
To Remove catalytic converter?
