Plugs for LT1
Old Feb 16, 2004 | 06:04 PM
JohnOH327's Avatar
JohnOH327
Default Plugs for LT1
I am considering Bosch Platinum +4 plugs for my 95 LT1 engine. Installed a set in my van about 50,000 miles ago and still running great plus added performance. Will these work good in the LT1? Also, should I replace the wires with stock or aftermarket? Thanks, John
Old Feb 16, 2004 | 06:17 PM
BowTieBlood's Avatar
BowTieBlood
Default Re: Plugs for LT1 (JohnOH327)
NGK :thumbs:
Old Feb 16, 2004 | 07:04 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: Plugs for LT1 (BowTieBlood)
I have read about too many problems with Bosch Platinum plugs in the LT1's. Most people (Corvettes and F-bodies) use NGK TR55 plugs. Cheap and reliable :thumbs:
Old Feb 16, 2004 | 07:28 PM
JB666's Avatar
JB666
Dont do it! There are a few here that have been ok with them, but more people have had problems.
They (Bosch) replaced them in another vehicle of mine when they discovered they don't work well with modded computers... Either way, I'll never use them again.
Old Feb 16, 2004 | 07:46 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Plugs for LT1 (Jbaker)
NGK's for three years here! :thumbs:
Old Feb 16, 2004 | 08:15 PM
MSR's Avatar
MSR
platinum plugs have a double-whammy against them. first, they're hotter than usually required for the application. second, the platinum tips/pucks are very susceptible to detonation (which will happen more readily if the plugs are too hot).
i haven't looked closely at the newer designs, but on the single electrode bosch platinums the platinum core blew out multiple times for me. it caused missing under load at wot. it took me a while to figure it out since the core is so tiny that i didn't immediately see it was missing.
my vote is for NGK TR55s.
-michael
Old Feb 16, 2004 | 08:43 PM
Strick's Avatar
Strick
NGK TR55IX Iridiums Great quality plug. Great if you are not going to change every 10k or so.
Old Feb 16, 2004 | 09:24 PM
wake's Avatar
wake
Default Re: Plugs for LT1 (94vette)
I never had any problems with +4s... I run them in my daily driver and they were also in my previous LT1 Vette... Both used +4s for over 2 years without any problems... I also put them in my ex-gf's Cavalier and she never had any problems with the plugs either...
I installed the standard TR55s in my Vette last night only because I wanted to try them after the rave reviews here... But I wouldn't have hesitated to put the +4s into this Vette either... The car does run better on the TR55s, but 5 of the original Delco plugs were missing the pucks and had a ~.65 gap which helps explain the increased running quality...
Old Feb 16, 2004 | 09:33 PM
bogus's Avatar
bogus
Default Re: Plugs for LT1 (wake)
I have the NGK TRX Iridium in my 92, they are great!
When I got the Vette, I quickly replaced the AC-Delco plugs, with more AC-Delco plugs. A friend said, "use the factory part". I did... NEVER AGAIN.
I am much happier with the NGK's...
Old Feb 16, 2004 | 10:22 PM
lspalding's Avatar
lspalding
Have the NGKTR55ix in my 383. Absolutely love them.
BTW, have a brand new set of NGKTR55 copper I'll send you for $10 if you're interested.
Old Feb 16, 2004 | 10:36 PM
Lone Ranger's Avatar
Lone Ranger
Don't use Bosch +4's. The way the plug is presented to the combustion chamber on LT1's, LT4's, L98's the open electrode design of the Bosch +4's is not optimal. A plug with the standard design L-shaped ground strap is best. I've tried new sets of the following plugs in my '95:
1. AC 41-906 (OEM double platinum)
2. NGK TR55 v-power
3. NGK TR55ix iridium
4. AC Rapidfire #14
I like the AC Rapidfire's best. The AC 41-906 stock plug was okay, just that i was paranoid about the pucks coming off as some have reported... don't need a scored cylinder wall.
Old Feb 16, 2004 | 10:47 PM
Lone Ranger
Default Re: Plugs for LT1 (MSR)
What evidence are you basing the increased-detonation tendency on, about the platinum pucks? I'm not calling :bs I just don't see how GM would use them as OEM if they are known to pre-dispose towards towards extra knock/detonation. Contrary to popular belief GM powertrain engineers draw on a lot of tech data and research when putting together the total package to bring to market an engine that still meets fleet average mpg requirements and EPA emissions limits yet produces industry leading (for the era) power. And Delphi, the company that OEM's most of the AC Delco powertrain control electronics and ignition components, is no slouch at R&D either. Delphi makes the various double platinum plugs for AC that are used in the LT1, LT4, LS1, and LS6 engines.
What you say may in fact be the case with double platinum plugs, but if so I don't see how it got past the aforementioned parties.
Old Feb 16, 2004 | 11:15 PM
MSR's Avatar
MSR
Default Re: Plugs for LT1 (Lone Ranger)
sorry, i was refering specifically to bosch platinums. if you look through their cross-reference catalog, you'll notice the same plug part number is specified for a wide heat range.
with the stock plugs from GM, though, then you run into the detached puck problem.
-michael
Old Feb 17, 2004 | 03:09 AM
gears's Avatar
gears
Ive had the +4's in my vette going on 2 years now,and they havent missed a lick.Seen 6200-6400 rpm's a few times too :D .I like em :thumbs:
[Modified by gears, 2:10 AM 2/17/2004]
Old Feb 17, 2004 | 09:17 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: Plugs for LT1 (gears)
I guess I'm the odd man out here...I put in plain old Autolite plugs last October...mine is a daily driver and I do drag race it a lot too...bought the car with Plus 4's...went to Rapidfires...now these coupled with Moroso wires...no problemo's..
Old Feb 17, 2004 | 09:23 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Default Re: Plugs for LT1 (Fuzzy Dice)
The Bosch plugs caused a high RPM miss in my LT-1. I had them gapped perfectly too. They do not match with the Lt-1 I dont know why.
Get AC Delco Platnum's or the NGK. :smash: :thumbs:
Old Feb 17, 2004 | 10:10 AM
Kizmo's Avatar
Kizmo
Default Re: Plugs for LT1 (VictorRussell'92)
I have had the plus 4s in my 95 LT1 for 2 years now and have never had any problems.
To Plugs for LT1
