HELP!
Old Feb 16, 2004 | 06:48 PM
Preacher's Avatar
Preacher
Cruise-In IV Veteran
Default HELP!
You may or may not have seen a thread by me whining about the stuck post on my battery. I finally got it out, but I have a new problem.
When I was runnng wire day before yesterday for my new stereo, I noticed a clicking sound from onder the passenger side dash. I had already pulled th stereo out and figured I had screwed something up. Rather than let it drain the battery (I have no idea how long it was happening berfore I noticed it) I figured I would just unhook the battery.
That's when I found the bad terminal.
Anyway.... I got the amps, speakers and sub installed, just wired up the head unit, replaced both terminals and re-connected the battery.
That sound is still there and I haven't a clue what the hell it is. The battery is pretty low and whatever that clicking is is draining a lot of power!
When I turn the key to the acessory postion, the sound stops.
Any ideas?
FWIW: I enjoyed learning a lot about my car with this install, but if I had known what a major pain in the azz it was going to be I would have paid somone else to do it.
Old Feb 16, 2004 | 06:52 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: HELP! (Preacher)
I believe it has to do with the security system. Some people have also reported getting a SYS light after a stereo swap. Try posting in the stereo forum for more information. :cheers:
Dilligas's Avatar
Dilligas
Could it be a circuit breaker opening and closing? I am not sure where the fuse box is on your car but you may want to check and see if a CB there is making the noise.
Old Feb 16, 2004 | 07:09 PM
Preacher's Avatar
Preacher
Default Re: HELP! (JCAIRE2)
I just got the same tip from a buddy of mine who is great with C4's... evidently, the almost dead battery doesn't have enough power to start the security system and it keeps cycling...
Good job on the spot diagnosis...
I'll jump it and let you know what happens....
Old Feb 16, 2004 | 07:30 PM
Preacher's Avatar
Preacher
I hooked the vette up to the wife's car and the clicking went away.... the stereo came on (only 1 speaker though, gotta check the connections at the amp, see if I have them backwards)
BUT... when I tried to start the car, the entire car went dead. No radio, no lights, no dash, nothing.
Think I cracked the battery fighting with that corroded terminal for 2 days? :nonod: :sad:
Old Feb 16, 2004 | 07:43 PM
C490Vette's Avatar
C490Vette
I had kind of the same problem recently. There was a continuos clicking coming from the passanger side of the car. Turned out the battery was dead. But to stop the clicking I just started pulling fuses until it stopped. The clicking stopped when I pulled the interior light fuse which I think also controls the environmental controls. I dunno. Maybe this help. Good luck.
:thumbs:
To HELP!
